for some reason all my genesis roms don't display the proper game titles.. for example Bimini Run just says Bimini.. is there somwhere i can change this or fix it?
Are they named properly? You can do a google search for goodtools genesis to download a tool to rename them. I'm not sure of a setting in GameEx that would fix this if its not a naming problem. I would suggest trying a different theme but you only mention genesis doing this. Not real sure other than the goodtools thing. maybe someone else has seen this happen.
Jay T
  • 1 month later...
