Yo dudes; I've lost all my tables a while ago; but after collecting them back I installed vpinball 7 and the latest pinmame again (with the vbsscript 2.6).
When I start a table in GameEx all seems to load fine untill pinmame loads and runs its screen full-screen (on top of the tablescreen).
I don't know anymore how I've solved this earlier so I can't find a proper solution to change the size by default..
When I press Alt-Enter nothing happens (to swap fullscreen-windowed mode) and when I try to change the screenformat with the mouse the display just dissapears and the table becomes very glitchy or even stops running..
Anybody know a fix? I'm running XP SP2; maybe my screensize is too 'incompatible'? Currently I'm running GameEx at 1440x900
PS: Tom; you're update-frequency is incredible! All heil Tom ;)
I'd check here I heard there is a great tutorial on getting this setup with all needed files.
http://www.gameex.net/Support/Tutorials/ta...79/Default.aspx
