Hi All
I've searched the forum and tried a couple of bits of advice but with no luck
1) I've installed the latest K-Lite Codecs
2) I'm trying to create a snap / play video for two video files
3) One has MPEG1 as video / audio codec (using Gspot) and is fine in terms of creating the snap / playing the video
4) The other is MPEG1 Audio but has a video codec of Xvid MPEG4. This one creates no snap and playing the video results in a black screen..
The problematic file is fine when played outside of Gameex but I'm obviously doing something wrong
I seem to be going around in circles and would appreciate any advice.
Cheers
Blueboy
Hi All
Cheers
Blueboy
Hi. I would uninstall the K-Lite codecs and install ffdshow http://tomspeirs.com/gameex/Extras.htm as it works best with GameEX.
EDIT: You can select to use mpeg1 & 2 during the install if you need them.
Thanks for that advice Iano
That corrected the problem..
I've got a couple of large video files (around 300MB) and the create snap feature only adds an actual "snap shot" picture rather than a video preview.
Has anyone had this before and can it be solved ?
Blueboy
Blueboy
I'm almost sure GameEX will not do this. You'll have to use video capturing software like fraps or something.
http://www.fraps.com/download.php
EDIT: I may of misunderstood your post. Do you want to create video previews of your games or just get GameEX to display your video previews of your games ?
Ok..Thanks for the clarification
I assumed you had to "create snaps" on the video menu to generate the "video previews"..
Having said that I've got a couple of files that don't "play" a preview but purely a static snap picture of the video file..
When you select to play them they play fine but Gameex doesn't seem to play them in "preview mode"
Hope that clarifies what I meant :)
Blueboy
