Does gameex support transparencies on the png images and if so, what rgb is being sought by the app to translate it.
Thanks,
-Wolfen
Thanks,
-Wolfen
it doesn't pick up on adobe's transparencie, but i was told that if you fill an image black, it won't show up in gameex.
help any?
help any?
Yes of course it wont pick up PS's trans hehe. I just knew most apps using themes, particularly using PNG's use different colors for there transparencies.
Black is a good start. I wonder if it is rgb 000 or 001 and so on though. Ill take a look at the other themes for the black value.
Thanks!!!!
