Thanks a million Tom, that seemed to have fixed this nagging problem. The only thing I did was remove the temppdf.pdf file from the DATA folder, because I had no Security tab in my folder properties. However, I can view the manuals now, thanks for sorting this problem out.
What was the cause of all this? maybe other users can prevent this problem from happening if we know what caused this problem..
Cheers to all who contributed on solving this..
Arjen
Your drive has to be ntfs not fat 32 partition and simple file sharing must be turned off to be able to see the security tab. I believe you can see it when you boot in to safe mode as well, as long as the drive is an ntfs partition. Just in case you were wondering why you couldn't see it.
Jay T
Where is the plugin on the GE website? I had to do a yahoo search with the filename to find it. I must be blind. I have it working but curious where the plugin is.
Its on the main download page at the bottom. It also allows you to download it when you install GameEx.
Yup..I was blind. Thanks.
