Hello All,
I have been working on changing the pc in my cab and I decided to upgrade to the most recent mame. I can't seem to get games to run now. I'm using mame32 - basically what is happening is the game tries to launch, I get a partial load screen and then the screen goes blank - after this I get solid rapid system beeps that will not end until I kill Mame32. When I try using dos mame the game acts like it is loading but all I get is a blank white screen. I've attached my log file below - any help would be appreciated. Thanks in advance.
***Update **** After messing with a few more settings it will now stop beeping at game startup if I hit escape again. The game will load OK after hitting escape to end the beeps... ????
System Specs
1.5 GHz Pentium 4
512 MB RAM
Nvidia GeForce4 MX
Mame32 115-4
16:12:51.8 6/13/2007: GameEx: Version 8.15: Starting Log
16:12:51.8 6/13/2007: Operating System Platform: Win32NT
16:12:51.8 6/13/2007: Operating System Name: Windows XP
16:12:51.8 6/13/2007: Operating System Version: 5.1.2600
16:12:51.8 6/13/2007: Checking for versions of .net Framework installed
16:12:51.8 6/13/2007: .net Framework 2.0 Installed
16:12:51.8 6/13/2007: Intel® Pentium® 4 CPU 1.50GHz
16:12:51.8 6/13/2007: 1.5Ghz
16:12:51.8 6/13/2007: Running Randomize()
16:12:51.8 6/13/2007: Loading PlugIns
16:12:51.9 6/13/2007: Checking for applications to Launch On Startup
16:12:51.9 6/13/2007: Running Misc startup tasks
16:12:51.9 6/13/2007: Setting Menu types
16:12:51.9 6/13/2007: Opening Configuration File
16:12:51.9 6/13/2007: Getting Configuration Values
16:12:51.9 6/13/2007: Using Theme: Default - RedEx - Arcade800x600
16:12:51.9 6/13/2007: Checking for alternate Image Directory for Theme: Default - RedEx - Arcade800x600
16:12:51.9 6/13/2007: Launching HideOS.exe
16:12:51.9 6/13/2007: Initialising Video/MNG DLL's
16:12:51.9 6/13/2007: Arcade Mode is on
16:12:51.9 6/13/2007: Hiding Taskbar
16:12:51.9 6/13/2007: Is Media Center running?
16:12:51.9 6/13/2007: Checking/Creating LCD Registry values
16:12:51.9 6/13/2007: Check Media Center Exit/Start Mode
16:12:51.9 6/13/2007: Media Center Mode 2
16:12:51.9 6/13/2007: Video previews on. Warning: Only recommended on modern systems
16:12:52.0 6/13/2007: Snap Delay set to: 2
16:12:52.0 6/13/2007: Get other settings
16:12:52.0 6/13/2007: Mouse Input is disabled
16:12:52.1 6/13/2007: Set: Find emulator artwork on best match basis
16:12:52.1 6/13/2007: Start work for Form
16:12:52.1 6/13/2007: Getting Original Screen Size
16:12:52.1 6/13/2007: Opening Database Connection
16:12:52.2 6/13/2007: Initializing Component
16:12:52.4 6/13/2007: Initialising Windows Media Player Component
16:12:52.5 6/13/2007: MAME Path is: E:\mame32b115-4
16:12:52.5 6/13/2007: MAME EXE file is: mame32.exe
16:12:52.5 6/13/2007: ROM Paths are: E:\mame32b115-4;E:\mame32b115-4\roms
16:12:52.5 6/13/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
16:12:52.5 6/13/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
16:12:52.5 6/13/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
16:12:52.5 6/13/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
16:12:52.5 6/13/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
16:12:52.5 6/13/2007: Loading Controls.ini map file
16:12:52.5 6/13/2007: Snap Path is: E:\mame32b115-4\snap
16:12:52.5 6/13/2007: AVI Snap Path: Not Found
16:12:52.5 6/13/2007: Flyer Path is: E:\mame32b115-4\flyers
16:12:52.5 6/13/2007: Cabinet Path is: E:\mame32b115-4\cabinets
16:12:52.5 6/13/2007: Title Path is: E:\mame32b115-4\\titles
16:12:52.5 6/13/2007: Panel Path is: E:\mame32b115-4\cpanel
16:12:52.5 6/13/2007: Manual Path: Not Found
16:12:52.5 6/13/2007: Icon Path: Not Found
16:12:52.5 6/13/2007: Marquee Path is: E:\mame32b115-4\marquees
16:12:52.6 6/13/2007: Loading Custom Emulators
16:12:53.0 6/13/2007: Using 2D Animations
16:12:53.0 6/13/2007: Using General Font: Trebuchet MS
16:12:53.0 6/13/2007: Using Title Font: Trebuchet MS
16:12:53.0 6/13/2007: MAME CMD options: -triplebuffer -nowindow
16:12:53.0 6/13/2007: Attempting to load game list
16:12:53.2 6/13/2007: Initialising DirectDraw
16:12:55.1 6/13/2007: Creating DirectDraw Device
16:12:55.1 6/13/2007: Using Device: Primary Display Driver
16:12:55.1 6/13/2007: 62mb video memory available
16:12:55.2 6/13/2007: Setting Resolution to 800x600 32 bit color
16:12:55.2 6/13/2007: Creating DirectDraw Surfaces
16:12:55.2 6/13/2007: Creating Primary Surface - Full Screen Mode
16:12:55.2 6/13/2007: Creating Back Buffer
16:12:55.4 6/13/2007: Loading graphic Surfaces
16:12:55.5 6/13/2007: Creating Surfaces Misc and Dialogs
16:12:55.5 6/13/2007: Creating Surfaces Volume
16:12:55.6 6/13/2007: Creating Surfaces Arrows
16:12:55.6 6/13/2007: Creating Surfaces GameEXlogo Text
16:12:55.6 6/13/2007: Creating Surfaces Toolbar
16:12:55.6 6/13/2007: Creating Surfaces Backgrounds
16:12:55.8 6/13/2007: Creating Surfaces Toolbar Controls
16:12:55.9 6/13/2007: Creating Surfaces GameEx Logo
16:12:55.9 6/13/2007: Creating Surfaces Home & Exit
16:12:55.9 6/13/2007: Creating Surfaces Snaps
16:12:55.9 6/13/2007: Creating Surfaces Menu and List Bars
16:12:56.0 6/13/2007: Creating Fonts
16:12:56.0 6/13/2007: Creating Menu Font
16:12:56.1 6/13/2007: Restoring Menu Font From Cache
16:12:56.1 6/13/2007: Creating Game Font
16:12:56.2 6/13/2007: Creating Font Black
16:12:56.5 6/13/2007: Creating Font Black Small
16:12:56.8 6/13/2007: Creating Game Font Faded
16:12:56.9 6/13/2007: Creating Title Font
16:12:57.0 6/13/2007: Restoring Title Font From Cache
16:12:57.1 6/13/2007: Fonts Created Succesfully
16:12:57.1 6/13/2007: 42mb video memory left available
16:13:20.1 6/13/2007: Text/Language: English
16:13:20.1 6/13/2007: Applying Language/Text
16:13:20.2 6/13/2007: Initialising Bass Audio Library
16:13:20.4 6/13/2007: Loading last used Game List
16:13:20.4 6/13/2007: Setting Music Volume
16:13:20.4 6/13/2007: Creating DirectSound Device
16:13:20.4 6/13/2007: Trying: Primary Sound Driver
16:13:20.5 6/13/2007: Loading Sound Files
16:13:20.5 6/13/2007: DirectSound Device Created Successfully
16:13:20.5 6/13/2007: Gamepad/Joystick disabled
16:13:20.5 6/13/2007: Playing intro sound file
16:13:20.5 6/13/2007: Initializing MCE Remote
16:13:20.5 6/13/2007: Initialization OK! Starting GameEx!
16:13:20.5 6/13/2007: Testing Main Loop Once: Processing Frame
16:13:21.3 6/13/2007: Testing Main Loop Once: Main Loop ran successfully
16:13:34.4 6/13/2007: Running: cmd.exe /c E: E:\mame32b115-4\mame32.exe 005 -rompath E:\mame32b115-4;E:\mame32b115-4\roms -triplebuffer -nowindow
16:14:27.9 6/13/2007: Exiting GameEx!
16:14:27.9 6/13/2007: Saving Settings
16:14:29.4 6/13/2007: Disposing Plugins
16:14:29.4 6/13/2007: Closing database connection
16:14:29.4 6/13/2007: Checking for applications to Launch On Exit
Hello All,
System Specs
1.5 GHz Pentium 4
512 MB RAM
Nvidia GeForce4 MX
Mame32 115-4
i'm not sure if it's a mame32, or gameex error. but i used to use mame32 but was told to get mameplus because it normalizes audio in games like mortal kombat (who's volume is unusually low in other mame versions) - i recently formatted my pc and downloaded the latest mamep and all lights are green over here.
EDIT** i know volume wasn't your issue, what i mean is my mameplus is working if you want to try that emulator.
Looks to me like you have a wacky path. I haven't had any loading troubles with either cmd mame, Mame32, or advancemame (once I got everything set correctly).
I use vanilla MAME and I am not seeing any problems like this. Did you run the 'Verify Setup' option after you set up GameEx? You can find the option on the setup wizard. If it was a wacky path the wiz would tell you. It almost sounds like a problem with your build of M32... You using an experimental version... like 115u4 or some crazy thing? If so, we unfortunately don't offer support for any build other than stable builds (like 114, 115, etc.)
Also, is this every game or specific sets or BIOSes? Does your Attract Mode function properly?
I also noticed you don't have a command line argument for Direct3D... I don't think that's the issue, but if it's been awhile since you updated MAME a lot of things have changed this year - especially in the rendering department.
