Decided to organize, update and re-install everything. So I wiped out my arcade mahcine and started everything over. problem is once I am done I get this error:
14:23:40.6 6/13/2007: Loading Custom Emulators
14:23:40.7 6/13/2007: Loading Emulator 1: Nintendo 64 Games
14:23:41.2 6/13/2007: Loading Emulator 2: Nintendo SNES games
14:23:41.4 6/13/2007: Error: Emulator_2: 7-Zip/Goodmerge support is a registered version only feature
14:23:41.4 6/13/2007: --Please correct the error above for this emulator or disable the emulator.
14:23:41.4 6/13/2007: ---------------------------------
14:23:41.4 6/13/2007: Error: Procedure call or argument is not valid.
14:23:41.4 6/13/2007: at Microsoft.VisualBasic.ErrObject.Raise(Int32 Number, Object Source, Object Description, Object HelpFile, Object HelpContext)
14:23:41.4 6/13/2007: at GameEx.GameEx.mainform.InitialEmuLoad()
14:23:41.4 6/13/2007: at GameEx.GameEx.mainform.InitGameEx(Boolean reinit, String ctheme, Boolean nohideos)
14:23:41.4 6/13/2007: at GameEx.GameEx.mainform..ctor()
14:23:41.4 6/13/2007: Closing database connection
14:23:41.5 6/13/2007: GameEx is exiting with errors
14:23:42.9 6/13/2007: ERRORS DETECTED: EXITING
My Arcade Machine uses XP Pro
This also happens on another mahcine that is using Vista Home Premium
Basically, its exactly as it says in the log.
Go ahead and change the settings for emulator 2. Basically turn off 7-zip. Sounds like 7-zip maybe a new feature since you upgraded GameEx and its putting in a default. In addition, as we're old buddies, your welcome to a free registered version of GameEx anyway, obviously. Drop me a mail if thats the issue.
Hehe... looked through the config lots of times and idnt see that :D oh well we all have our moments lol
Yeah havent messed around wiht anything for a longtime, and havent been on much at all :) but back to playing around a little bit :) been nearly two years since I initially setup the arcade machine lol.... alot has been updated since then!
I'll wait till I get some cash to put in to paypal and support you :) you have done a lot of hard work and every little bit helps!
