Can anyone help me figure out how to add a snap window in the NexGen theme. I really like how the theme looks however I'm unable to get any snaps to see what the games look like. Any help would be great.
Do you get snaps in any other themes? If not, it may be because they're zipped. I wanted to use titles instead and found they were zipped and weren't showing.
So can I set up a snap window while using a theme? If so, how do I do it?
There's already a snap window in NextGen (I'm pretty sure), and all the others I'm aware of. If you have these snaps, they need to follow this criteria:
  1. All snaps must have the same name as the ROM.
  2. They must be in AVI, JPEG or PNG format.
  3. They must be uncompressed or unzipped
  4. GameEx must have the snap path under the individual emulator's setup.
If your snaps don't meet this criteria, they won't show.
Hope that helps!
