zsnes... ahem...
So it won't launch any games?
HI
Me i have a little also the same problem : gameex wont play any games on all emulators with % percent in the filename.
When i'm in debug mode i see command line :
zsnesw.exe "E:\SNES\Rom\Chrono Trigger (U) [T-Fre101_Terminus+Tbex].zip"
original filename is "Chrono Trigger (U) [T-Fre101%Terminus+Tbex].zip"
then gameex replace percentage character to underscore
How do please?
zsnes... ahem...
It launches some games, except those with () in the title. (i think the parenthesis are the problem)
Gamex launches all the other emulators games with codes in the names, i dont think i changed any setting on zsnes.
try adding all the endings (j) (u) (e) in the filter of the gameex config. just a thought.
