HI everyone. I'm new to gameex and am having trouble installing it.
This is what I get when I try to execute the program trough mce:
UNABLE TO DISPLAY PAGE
media center was unable to load the page K:\documents and settings\eman\local
settings\temp\is-AHQQ9.tmp\gameex.exe.
the program or web site cannot be found.
ensure that the program is on the computer
or that you have a working internet connection.
I should point out that I have 2 hard drives, C: and K:. I have windows on drive K: and nothing on C:.
any help would be very appreciated.
GameEx doesn't care where it's loaded so having it on drive K: is "ok" ;)
There is no reason why it should be looking for something in a hidden directory tho.
Uninstall GameEx. This time your installation path should be set to k:\program files\GameEx
Make sure you select the option to integrate into MCE "something along those lines anyway"
