Hi i am a registered user and am trying to get my LCD working via LPT (Parallel) port.
I have the latest software and plug-in (lcdSmartie) but i cant seem to get any functions above "5" to work
I have also tried the newest LCD plug-in (LCD/LED Plug-in 1.92) but it doesn't support the LPT (Parallel) port..
How do i get GameEx to send the controls for playing a Mame game to my LCD?
Please post your gameex log.
17:58:57.1 4/27/2007: GameEx: Version 8.07: Starting Log
17:58:57.1 4/27/2007: Operating System Platform: Win32NT
17:58:57.1 4/27/2007: Operating System Name: Windows XP
17:58:57.1 4/27/2007: Operating System Version: 5.1.2600
17:58:57.1 4/27/2007: Checking for versions of .net Framework installed
17:58:57.1 4/27/2007: .net Framework 1.1 Installed
17:58:57.1 4/27/2007: .net Framework 2.0 Installed
17:58:57.2 4/27/2007: Intel® Pentium® 4 CPU 2.00GHz
17:58:57.2 4/27/2007: 2Ghz
17:58:57.2 4/27/2007: Running Randomize()
17:58:57.2 4/27/2007: Loading PlugIns
17:58:57.2 4/27/2007: Checking for applications to Launch On Startup
17:58:57.2 4/27/2007: Running Misc startup tasks
17:58:57.2 4/27/2007: Setting Menu types
17:58:57.2 4/27/2007: Opening Configuration File
17:58:57.2 4/27/2007: Getting Configuration Values
17:58:57.2 4/27/2007: Using Theme: Default - Default - Animated
17:58:57.2 4/27/2007: Checking for alternate Image Directory for Theme: Default - Default - Animated
17:58:57.2 4/27/2007: Using Images from theme: Default - Default\MEDIA\
17:58:57.2 4/27/2007: Launching HideOS.exe
17:58:57.2 4/27/2007: Initialising Video/MNG DLL's
17:58:57.2 4/27/2007: Hiding Taskbar
17:58:57.2 4/27/2007: Is Media Center running?
17:58:57.2 4/27/2007: Checking/Creating LCD Registry values
17:58:57.2 4/27/2007: Check Media Center Exit/Start Mode
17:58:57.2 4/27/2007: Media Center Mode 2
17:58:57.2 4/27/2007: Video previews on. Warning: Only recommended on modern systems
17:58:57.3 4/27/2007: Snap Delay set to: 3
17:58:57.3 4/27/2007: Get other settings
17:58:57.3 4/27/2007: Set: Find emulator artwork on best match basis
17:58:57.3 4/27/2007: Start work for Form
17:58:57.3 4/27/2007: Getting Original Screen Size
17:58:57.3 4/27/2007: Initializing Component
17:58:58.7 4/27/2007: Creating Radio Station Genres
17:58:59.3 4/27/2007: Succesfully created station genres
17:58:59.3 4/27/2007: MAME Path is: C:\Documents and Settings\Administrator.JUKEBOX\Desktop\Mame32
17:58:59.4 4/27/2007: MAME EXE file is: Mame32.exe
17:58:59.5 4/27/2007: ROM Path is: C:\roms
17:58:59.5 4/27/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
17:58:59.5 4/27/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
17:58:59.5 4/27/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
17:58:59.5 4/27/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
17:58:59.5 4/27/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
17:58:59.5 4/27/2007: Loading Controls.ini map file
17:58:59.5 4/27/2007: Snap Path is: C:\Documents and Settings\Administrator.JUKEBOX\Desktop\Mame32\snap\snap
17:58:59.5 4/27/2007: AVI Snap Path: Not Found
17:58:59.5 4/27/2007: Flyer Path: Not Found
17:58:59.5 4/27/2007: Cabinet Path: Not Found
17:58:59.5 4/27/2007: Title Path: Not Found
17:58:59.5 4/27/2007: Panel Path: Not Found
17:58:59.5 4/27/2007: Manual Path: Not Found
17:58:59.5 4/27/2007: Icon Path: Not Found
17:58:59.5 4/27/2007: Marquee Path: Not Found
17:58:59.7 4/27/2007: Loading Custom Emulators
17:58:59.7 4/27/2007: Loading Emulator 1: Nintendo 64 Games
17:58:59.8 4/27/2007: Loading Emulator 2: Nintendo SNES games
17:58:59.8 4/27/2007: Loading Emulator 5: Atari 2600 (Stella)
17:58:59.9 4/27/2007: Loading Emulator 9: Sega Master System
17:59:00.1 4/27/2007: Using 2D Animations
17:59:00.1 4/27/2007: Using General Font: Trebuchet MS
17:59:00.1 4/27/2007: Using Title Font: Trebuchet MS
17:59:00.1 4/27/2007: Initialising DirectDraw
17:59:00.5 4/27/2007: Creating DirectDraw Device
17:59:00.5 4/27/2007: Using Device: Primary Display Driver
17:59:00.7 4/27/2007: 55mb video memory available
17:59:00.9 4/27/2007: Setting Resolution to 768x1024 32 bit color
17:59:00.9 4/27/2007: Creating DirectDraw Surfaces
17:59:00.9 4/27/2007: Creating Primary Surface - Full Screen Mode
17:59:01.4 4/27/2007: Creating Back Buffer
17:59:01.6 4/27/2007: Loading graphic Surfaces
17:59:01.7 4/27/2007: Creating Surfaces Misc and Dialogs
17:59:01.9 4/27/2007: Creating Surfaces Volume
17:59:01.9 4/27/2007: Creating Surfaces Arrows
17:59:01.9 4/27/2007: Creating Surfaces GameEXlogo Text
17:59:01.9 4/27/2007: Creating Surfaces Toolbar
17:59:01.9 4/27/2007: Creating Surfaces Backgrounds
17:59:07.1 4/27/2007: Creating Surfaces Toolbar Controls
17:59:07.2 4/27/2007: Creating Surfaces GameEx Logo
17:59:07.2 4/27/2007: Creating Surfaces Home & Exit
17:59:07.2 4/27/2007: Creating Surfaces Snaps
17:59:07.2 4/27/2007: Creating Surfaces Menu and List Bars
17:59:07.3 4/27/2007: Creating Fonts
17:59:07.3 4/27/2007: Creating Menu Font
17:59:07.4 4/27/2007: Restoring Menu Font From Cache
17:59:08.2 4/27/2007: Creating Game Font
17:59:08.4 4/27/2007: Creating Font Black
17:59:08.6 4/27/2007: Creating Font Black Small
17:59:08.8 4/27/2007: Creating Game Font Faded
17:59:08.9 4/27/2007: Creating Title Font
17:59:09.0 4/27/2007: Restoring Title Font From Cache
17:59:09.8 4/27/2007: Fonts Created Succesfully
17:59:09.8 4/27/2007: 1mb video memory left available
17:59:09.9 4/27/2007: Starting GameExtender Publisher
17:59:09.9 4/27/2007: Text/Language: English
17:59:09.9 4/27/2007: Applying Language/Text
17:59:10.0 4/27/2007: Initialising Bass Audio Library
17:59:10.2 4/27/2007: MAME CMD options: -triplebuffer -nowindow -joy
17:59:10.2 4/27/2007: Attempting to load game list
17:59:10.4 4/27/2007: Loading last used Game List
17:59:10.4 4/27/2007: Setting Music Volume
17:59:10.4 4/27/2007: Cannot Load Play List. Check Path and filename
17:59:10.4 4/27/2007: Creating DirectSound Device
17:59:10.5 4/27/2007: Trying: Primary Sound Driver
17:59:10.5 4/27/2007: Loading Sound Files
17:59:10.6 4/27/2007: DirectSound Device Created Successfully
17:59:10.6 4/27/2007: Initialising DirectInput for Gamepad support
17:59:10.7 4/27/2007: Unable to create a joystick device
17:59:10.7 4/27/2007: Playing intro sound file
17:59:10.7 4/27/2007: Initializing MCE Remote
17:59:10.7 4/27/2007: Initialization OK! Starting GameEx!
17:59:10.8 4/27/2007: Testing Main Loop Once: Processing Frame
17:59:11.5 4/27/2007: Testing Main Loop Once: Main Loop ran successfully
18:01:00.7 4/27/2007: Running: cmd.exe /c C: C:\Documents and Settings\Administrator.JUKEBOX\Desktop\Mame32\Mame32.exe 19xx -rompath C:\roms -triplebuffer -nowindow -joy
18:01:32.6 4/27/2007: Exiting GameEx!
18:01:32.6 4/27/2007: Saving Settings
18:01:34.7 4/27/2007: Disposing Plugins
18:01:34.7 4/27/2007: Checking for applications to Launch On Exit
any ideas...
If you can handle this, can you run regedit.exe
Go to LOCAL MACHINE > SOFTWARE > GAMEEX
And see if you have a key called LCD, and if theres anything in there.
Thanks.
Tom
Yea they all seem to be there... After an auto update things are better.
Only i can't get controlls to display ,it just displays "playing" when in a game i am using script
$dll(GameEx.dll,2,8,1)
any ideas ?
My 4 line display arrived today and i'd love to get it happining...
Its working fine for me with latest version of Smartie. I selected 1942 and it showed the controls. However I did notice the plugin download on the LCD docs page is actually an old outdated one. The correct one is on the download page. That would certainly explain why you were not getting functions above a certain number.
Download the plugin again, I think that will do it.
Thanks.
Tom
