So far I love this program and everything has been going great except for one small problem. I want to remove the Most Played, Favorites, and Theme Picker menus from showing up in the program. I disabled them in the advanced configuration and yet they still show up. Everything else that I've disabled had no problems removing itself from the menu. Any suggestions?
I tried installing the current version (8.5) but that didn't change anything.
I'm not quite sure whats going on with your setup. I tried disabling Most Played and Favorites and it worked without issue. Perhaps you can provide a little more detail about your setup, and upgrade history etc?
Thanks.
Tom.
My upgrade history is short. I started this program on version 7.9. When I chose disable for those options it didn't work. I still can't figure out why but I thought it would be best to upgrade to the latest version before posting a question. Version 8.5 didn't fix the problem either. I've been playing around with the configuration files but so far I've only been able to rename the Most Played/Favorites in the Menu, but still can't disable them.
Aside from that, I'm running on XP Media Center 2002 SP2. Athlon 64 X2 Dual Core 3800+ 2GHz with 1GB ram. I'm trying to disable everything from the menu with the exception of just my emulators. Hope that information is useful.
