Just wanted to say Hi. Just discovered this amazing Entertainment Centre Suite. Seems like it deserves a more elaborate description than frontend.
First little annoyance I'm having is Thayer's Quest in Daphne seems to be starting in freeplay mode when launched without switches. When it is launched through DaphneLoader it defaults to coin mode.
I fully realize this is a Daphne commandline problem and has nothing to do with GameEx, but I needed something to say other than Hi, this sure is a boffo program!
Anybody have the -bank commandline that will fix that?
cheers
cheers
Read the log file daphne creates from Daphneloader, then cut and paste the switches added to the "framefile" line into your daphne configuration for Thayers Quest.
Brilliant! Thank you.
-bank 0 00010000
That did the trick!
