i'm using the alpha blue theme, it has the game list in the middle, and the avi video on the right. is it possible to somehow make the cabinet image appear below the video?
If the theme doesn't match exactly what you want it to, you could always just create your own. The easiest way is to take one that is close and modify it. Granted, I have only dabbled a little with the Theme Editor, but it does seem to work pretty well! One of these days I will actually make the one I keep envisioning (when I get off my lazy butt :blink: ), which will be more or less a combination of a few themes.
Basically, I'll step on the shoulders of giants ;)
I haven't personally run into any problems with the Theme Editor. Does it crash on load, when you load the theme in the editor, or when you load it in GameEx? The difference is where the problem is and who would be able to help solve it. If the Theme Editor crashes, then HeadKaze would probably need to help. If it's when you load the theme in to edit it, it could be a corrupt theme or a setting or something. Probably still a HeadKaze question. But, if it crashes in GameEx, that could be a badly formated or corrupt theme, an incompatibility with GameEx and the theme, or something else. In that case, it could be either HK or Tom.
Perhaps if you describe that problem in a little more depth, one of those guys can help.
