Hi All-
yes, I have been messing with my settings...(again) and forgot how to use the X-Arcade joystick with GAMEEX...Also, I am running GAMEEX on a 72" monitor and wondered if anyone has messed with display settings, as I am trying to fill the screen all the way, if possible. Thanks for the help!
If you are referring to bands on the side of your screen (if you have a widescreen display), then you need a theme that is built for widescreen displays :P If your monitor is standard 4:3 display, it should fill the screen just by setting "Full Screen" in GameEx which I think is default.
