i want to be able to change for example, MAME to say ARCADE GAMES when i'm in gameex menu.. is there a way to do this or do i have to create my own theme?
There is an option in the advanced setup wizard that allows you to change display text. I don't remember where it is at the moment, but as I recall, it was on the second page of the wizard.
Hi scurvy
What you are looking for is in the Advanced Configuration app. Open it up and then open Text/Language The drop down list should be set to -Custom- then you can change any of the text you need.
Ourgrace
