I launch GameEx from myHTPC (running fullscreen). Everything runs fine, but when I quit GameEx, instead of the focus returning to myHTPC, no application has the focus. After pushing the exit button, it looks like GameEx quickly minimizes, then dies. The problem is the task bar seems to get the focus, so even though myHTPC was running fullscreen, now its not, and I can't send commands to it.
Anyone have a similar problem launching GameEx from other front ends? Any workaround ideas? Any chance of a fix? Thanks.
Hi,
You could try this. Run GameEx via a batch (.bat) file, that on exit runs myHTPC.
Hopefully when myHTPC is run at the end it will regain focus. Most modern HTPC software regains focus or maximizes with this method. It works for Sage.
Create c:\runit.bat
C:
CD "\Program files\GameEx"
GameEx.exe
C:
CD "\Program files\Myhtpc"
myhtpc.exe
Tell myHTPC to run the batch file above instead of GameEx.exe
Let me know how it works out.
If not you could write an autoit script to do this fairly easily I would have thought.
Thanks,
Tom
Tom,
In a similar vein, do you have any suggestions on what to do about Media Center and its menu key? If someone presses the media center button while GameEx is up in full screen mode, Media Center tries to open and fails with a "Your video card or drivers are not compatible with Media Center" and runs it in a limited mode.
When this happens GameEx looses focus, and will not re-focus itself if you try and open GameEx again from the MCE interface. You have to grab a keyboard to get out from this state.
Tom,
I think a timer to check to see if ehshell is a running process and if so exit GameEx. With an option to enable this check. On by default.
My Home button never worked on my remote unless I have MCE open, so if i'd of known about this behaviour would have addressed months ago.
Probably be in next release.
I may also implement a shell on exit setting to address the issues above.
Cheers.
Tom
Just curious, and would like to know. Why are you using myHTPC and not GameEx alone. In other words what extra does myHTPC allow you to do that GameEx does not?
Thanks.
Tom,
Rob,
Can you please try the attached exe, and see if it resolves the issue?
Cheers.
GameEx.zip
Heh, there's the problem, myHTPC is pretty far from modern. Work stopped on it a while back when the author decided to start selling it and call it Meedio.
Anyway, thanks a ton for pointing out AutoIt. I was able to write a one line script to restore focus to myHTPC. I use a batch file to launch GameEx, and once GameEx dies, I run the focus script.
Rob,
Cheers.
I tested this by running ehshell when GameEx is loaded by scheduling ehshell with task scheduler.
Don't work :(
Not sure there is a viable solution to this at the moment. I understand the next version of MCE supports out of process apps, so it might have to wait until then.
Didn't really make a difference with the new exe.
You can test it without the MCE remote by assigning a hotkey to the ehshell shortcut. Go to the start menu, and right click on the Media Center shotcut, go to Properties. Click on the shortcut key and assign it to something like ctrl-alt-M.
Here's my suggestion on how GameEx can deal with it:
Monitor the task list for ehshell (or, monitor for that video card error dialog). If found, kill ehshell, then close down directx. Have GameEx load ehshell again (which will now succeed because DirectX isn't locking the display), then exit GameEx. Not pretty, but far superior to having to dig for a keyboard. ;)
Works perfectly for menow. Try This:
GameEx.zip
NICE! You are DA MAN!! When you do it with the real remote, it leaves MCE out of focus with the task bar over it, but that can be fixed by pressing the MCE button again. Great work!
-- Rob
  • 1 month later...
I am currently using GameEx 4.72 and the problem is back. When exiting GameEx with the GreenButton I receive an error: "your video card driver is not compatible with mce". then gameex exits and returns to mce.
Thank you for all the hard work. GameEx is amazing :D
Have you got MediaCenter mode set to 1 instead of 2?
And have you got the setting turned on to check for MCE.
There both under tweaks performance.
Confirmed - I have the same problem with 4.72. Media center mode is 2 and check for MCE is on.
MCE pops up the "your video card driver is not compatible with mce" box. GameEx then minimizes pretty quickly. It sits like that for a long time (about 20 seconds). MCE finally dies off, GameEx then closes and you do return to MCE ok. It just takes 100x as long as it used to. It used to all happen pretty smoothly.
-- Rob
-- Rob
What happens if you leave GameEx running for 25 seconds then press the Green Button?
There is a delay because the processes are cached in windows, and I was having GameEx detect the MCE was open when it was not.
See if this ones any better.
GameEx.zip
I tried that file and it still has the same problem.  MediaCenterMode = 2 and check for media center = true
Can you try this one, and also post the log so I can see where the slow down is occuring.
Thanks.
GameEx.zip
  • 1 month later...
I am using version 5.09 and the problem is still there. If running Project 64 and the Green Button is pressed, a message box pops up giving the video card driver error, then it closes and media center opens. If running ZSNES, and the Green Button is pressed, the screen goes black and the only way to recover is to ALT+TAB to set the focus back to ZSNES then close down properly. I posted the log below because of attach issues. Thank you for all your hard work.
18:33:29.8 9/17/2005: GameEx: Version 5.09: Starting Log
18:33:29.8 9/17/2005: Operating System Platform: Win32NT
18:33:29.8 9/17/2005: Operating System Name: Windows XP
18:33:29.8 9/17/2005: Operating System Version: 5.1.2600
18:33:29.8 9/17/2005: Checking Registration
18:33:29.8 9/17/2005: Running Randomize()
18:33:29.8 9/17/2005: Initialising Video/MNG DLL's
18:33:29.9 9/17/2005: Running Misc startup tasks
18:33:29.9 9/17/2005: Setting Menu types
18:33:29.9 9/17/2005: Opening Configuration File
18:33:29.9 9/17/2005: Getting Configuration Values
18:33:29.9 9/17/2005: Using Theme: Default - GameEx
18:33:29.9 9/17/2005: Checking for alternate Image Directory for Theme: Default - GameEx
18:33:29.9 9/17/2005: Text/Language: English
18:33:29.9 9/17/2005: Applying Language/Text
18:33:29.9 9/17/2005: Creating Scancodes.txt (List of DirectInput scan codes)
18:33:30.0 9/17/2005: Snap Delay set to: 2
18:33:30.0 9/17/2005: Is Media Center running?
18:33:30.0 9/17/2005: Media Center is running
18:33:30.0 9/17/2005: Check Media Center Exit/Start Mode
18:33:30.0 9/17/2005: Media Center Mode 2
18:33:30.1 9/17/2005: Closing Media Center
18:33:35.2 9/17/2005: Checking for applications to Launch On Startup
18:33:35.2 9/17/2005: Get other settings
18:33:35.2 9/17/2005: Using 2D Animations
18:33:35.2 9/17/2005: Mouse Input is disabled
18:33:35.2 9/17/2005: Launching HideOS.exe
18:33:36.3 9/17/2005: Hiding Taskbar
18:33:36.3 9/17/2005: Start work for Form
18:33:36.3 9/17/2005: Getting Original Screen Size
18:33:36.3 9/17/2005: Loading ICON
18:33:36.3 9/17/2005: Initializing Component
18:33:36.4 9/17/2005: Initialising Bass Audio Library
18:33:36.5 9/17/2005: Loading default loading screen
18:33:36.5 9/17/2005: Using General Font: HandelGothic BT
18:33:36.5 9/17/2005: Using Title Font: HandelGothic BT
18:33:36.5 9/17/2005: Initialising DirectDraw
18:33:36.5 9/17/2005: Applying GameEx is Loading Image
18:33:36.5 9/17/2005: Creating DirectDraw Device
18:33:36.6 9/17/2005: Setting Resolution to 720x480 32 bit color
18:33:36.6 9/17/2005: Creating DirectDraw Surfaces
18:33:36.6 9/17/2005: Creating Primary Surface - Full Screen Mode
18:33:36.6 9/17/2005: Creating Back Buffer
18:33:36.6 9/17/2005: Loading graphic surfaces
18:33:36.6 9/17/2005: Creating Surfaces Misc and Dialogs
18:33:36.7 9/17/2005: Creating Surface Volume
18:33:36.7 9/17/2005: Creating Surfaces Arrows
18:33:36.7 9/17/2005: Creating Surfaces GameEXlogo Text
18:33:36.7 9/17/2005: Creating Surfaces Toolbar
18:33:36.7 9/17/2005: Creating Surfaces Backgrounds
18:33:36.8 9/17/2005: Creating Surfaces Toolbar Controls
18:33:36.8 9/17/2005: Creating Surfaces GameEx Logo
18:33:36.8 9/17/2005: Creating Surfaces Home & Exit
18:33:36.9 9/17/2005: Creating Surfaces Snaps
18:33:36.9 9/17/2005: Creating Surfaces Menu and List Bars
18:33:37.0 9/17/2005: Creating Fonts
18:33:37.0 9/17/2005: Creating Menu Font
18:33:37.3 9/17/2005: Creating Game Font
18:33:37.7 9/17/2005: Creating Game Font Standard Size
18:33:37.9 9/17/2005: Creating Font Black
18:33:38.0 9/17/2005: Creating Font Black Small
18:33:38.1 9/17/2005: Creating Game Font Faded
18:33:38.3 9/17/2005: Creating Title Font
18:33:39.0 9/17/2005: Loading Controls.ini map file
18:33:39.0 9/17/2005: Loading Custom Emulators
18:33:39.0 9/17/2005: Loading Emulator 1: Nintendo 64 Games
18:33:39.1 9/17/2005: Loading Emulator 2: Nintendo SNES Games
18:33:39.1 9/17/2005: Loading Emulator 3: Nintendo NES Games
18:33:39.1 9/17/2005: Loading Emulator 4: SEGA Genesis
18:33:39.3 9/17/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
18:33:39.3 9/17/2005: Attempting to load game list
18:33:39.3 9/17/2005: Loading last used Game List
18:33:39.5 9/17/2005: Cannot Load Play List. Check Path and filename
18:33:39.5 9/17/2005: Creating DirectSound Device
18:33:39.5 9/17/2005: Trying: Primary Sound Driver
18:33:39.5 9/17/2005: Loading Sound Files
18:33:39.5 9/17/2005: DirectSound Device Created Successfully
18:33:39.5 9/17/2005: Initialising DirectInput for Gamepad support
18:33:39.5 9/17/2005: Looking for Device: Logitech Cordless RumblePad 2 USB
18:33:39.6 9/17/2005: Device Created
18:33:39.6 9/17/2005: Playing intro sound file
18:33:39.6 9/17/2005: Initializing MCE Remote
18:33:39.6 9/17/2005: Initialization OK! Starting GameEx!
18:33:39.6 9/17/2005: Testing Main Loop Once: Processing Frame
18:33:39.8 9/17/2005: Testing Main Loop Once: Main Loop ran successfully
18:34:06.6 9/17/2005: Validating: Emulator_1: Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_1: Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_1: Title Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_1: Title Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_1: Box Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_1: Box Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_1: Cart Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_1: Cart Art Path Does not exist
18:34:06.6 9/17/2005: Warning: Emulator_1: MAPFile Does Not Exist
18:34:06.6 9/17/2005: Validating: Emulator_2: Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_2: Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_2: Title Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_2: Title Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_2: Box Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_2: Box Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_2: Cart Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_2: Cart Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_3: Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_3: Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_3: Title Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_3: Title Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_3: Box Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_3: Box Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_3: Cart Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_3: Cart Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_4: Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_4: Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_4: Title Snap Path:
18:34:06.6 9/17/2005: Warning: Emulator_4: Title Snap Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_4: Box Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_4: Box Art Path Does not exist
18:34:06.6 9/17/2005: Validating: Emulator_4: Cart Art Path:
18:34:06.6 9/17/2005: Warning: Emulator_4: Cart Art Path Does not exist
18:34:22.2 9/17/2005: Running: cmd.exe /c C: zsnesw.exe "C:\Games\SNES\Donkey Kong Country 3 (Dixie Kong's Double Trouble).smc"
18:35:35.3 9/17/2005: Sending Q to emulator
18:35:55.1 9/17/2005: Running: cmd.exe /c C: zsnesw.exe "C:\Games\SNES\Donkey Kong Country 3 (Dixie Kong's Double Trouble).smc"
18:36:30.8 9/17/2005: Sending Q to emulator
18:36:38.1 9/17/2005: Running: cmd.exe /c C: zsnesw.exe "C:\Games\SNES\Donkey Kong Country 3 (Dixie Kong's Double Trouble).smc"
19:45:08.4 9/17/2005: Sending Q to emulator
19:45:40.1 9/17/2005: Running: cmd.exe /c C: zsnesw.exe "C:\Games\SNES\Donkey Kong Country 3 (Dixie Kong's Double Trouble).smc"
21:20:47.2 9/17/2005: Sending Q to emulator
21:20:49.8 9/17/2005: Sending Q to emulator
21:20:52.3 9/17/2005: Sending Q to emulator
21:20:54.7 9/17/2005: Sending Q to emulator
21:20:57.0 9/17/2005: Sending Q to emulator
21:20:59.4 9/17/2005: Sending Q to emulator
21:21:01.8 9/17/2005: Sending Q to emulator
21:21:04.1 9/17/2005: Sending Q to emulator
21:21:06.5 9/17/2005: Sending Q to emulator
21:21:08.9 9/17/2005: Sending Q to emulator
21:21:11.2 9/17/2005: Sending Q to emulator
21:21:13.6 9/17/2005: Sending Q to emulator
21:21:16.0 9/17/2005: Sending Q to emulator
21:21:18.3 9/17/2005: Sending Q to emulator
21:21:20.7 9/17/2005: Sending Q to emulator
21:21:23.0 9/17/2005: Sending Q to emulator
21:21:25.4 9/17/2005: Sending Q to emulator
21:21:27.8 9/17/2005: Sending Q to emulator
21:21:30.2 9/17/2005: Sending Q to emulator
21:21:32.5 9/17/2005: Sending Q to emulator
21:21:34.9 9/17/2005: Sending Q to emulator
21:21:37.2 9/17/2005: Sending Q to emulator
21:21:39.6 9/17/2005: Sending Q to emulator
21:21:42.0 9/17/2005: Sending Q to emulator
21:21:44.3 9/17/2005: Sending Q to emulator
21:21:46.7 9/17/2005: Sending Q to emulator
21:21:49.1 9/17/2005: Sending Q to emulator
21:21:51.5 9/17/2005: Sending Q to emulator
21:21:53.8 9/17/2005: Sending Q to emulator
21:21:56.2 9/17/2005: Sending Q to emulator
21:21:58.5 9/17/2005: Sending Q to emulator
21:22:00.9 9/17/2005: Sending Q to emulator
21:22:03.3 9/17/2005: Sending Q to emulator
21:22:05.6 9/17/2005: Sending Q to emulator
21:22:08.0 9/17/2005: Sending Q to emulator
21:22:10.4 9/17/2005: Sending Q to emulator
21:22:12.7 9/17/2005: Sending Q to emulator
21:22:15.1 9/17/2005: Sending Q to emulator
21:22:17.5 9/17/2005: Sending Q to emulator
21:22:19.8 9/17/2005: Sending Q to emulator
21:22:22.2 9/17/2005: Sending Q to emulator
21:22:24.6 9/17/2005: Sending Q to emulator
21:22:26.9 9/17/2005: Sending Q to emulator
21:22:29.3 9/17/2005: Sending Q to emulator
21:22:31.7 9/17/2005: Sending Q to emulator
21:22:34.0 9/17/2005: Sending Q to emulator
21:22:36.4 9/17/2005: Sending Q to emulator
21:22:38.7 9/17/2005: Sending Q to emulator
21:22:41.1 9/17/2005: Sending Q to emulator
21:22:43.5 9/17/2005: Sending Q to emulator
21:22:46.5 9/17/2005: Sending Q to emulator
21:22:48.8 9/17/2005: Sending Q to emulator
21:23:31.4 9/17/2005: Detected Media Center launched
21:23:31.4 9/17/2005: Killing Media Center
21:23:35.0 9/17/2005: Exiting GameEx!
21:23:35.0 9/17/2005: Saving Settings
21:23:37.5 9/17/2005: Checking for applications to Launch On Exit
21:23:37.5 9/17/2005: Launching Media Center
I think this is an issue with ZSNES rather than GameEx. If your using Media Center yourll probably find not using the advanced zsnes config and using MapKeys works much better if you press the Green button.
This issue is caused by Zsnes not linking Media Center loading while its using your graphics card. Your sending the Q key to exit, but its not responding, probably because its showing an error dialog. Either remove the key to send or dont use the advanced config. This gameEx will kill the ZSNES process, and should return to MCE eventually, and not hang.
Thanks.
