Is there any method to getting rid of the sort by year, manufacturer, genre from Mame and the Jukebox areas? I can get rid of them for the emulators.
Is there any way?
Doesn't that have something to do with Catver.ini in MAME? Or History.dat or MAMEInfo.dat? I can never remember which one is which. :P
As for the mp3s, you'd probably have to un-tag them? I din't think it's possible any other way,,,
I think he wants the categories removed from the display. I don't use the Jukebox, so I don't know what's listed, but it sounds like it has the same menus as the MAME list. I probably would want them gone, too. Sorry, can't help myself though...
I found out that in gameex there are databases that you can open with access. The emulator databases are wiped out but the files still exist the rom name names. It deactivates the menus on the left. Also, there might be a switch in each emulator menu in the gameex editor that turns off the databases. Try both.
But for the life of me, I can't find where MAME stores information for the categories to the left, such as manufacturer, year, etc. If anyone knows, please respond.
The above tips work. : )
The database is a great feature, definately one of GameEx's selling points. (Getting all philosophical after a few pints :))
But i'd like the option to disable the database too, i really like big screenshots of the games, plus like a lot of people i dont have a huge amount of mame roms.
[EDIT] Tom would it be possible to re-activate the background for the mame page? (MAMEbak.png).
p.s. keep up the good work, its coming on leaps & bounds!
