I tried setting up visual pinball but am having a problem... when I try to start a game it just hides gameex (still running as a process) and I can see that vpauto has an icon in the system tray, no game starts though. It works fine using visual pinmame and opening the game and hitting play. My tables are in R:\PinMAME\Tables and my roms are in R:\PinMAME\Roms, should these be together? Is it a problem using XPFix5?
[Emulator_23]
STARTPAGENAME=Pinball Games
TITLETEXT=Pinball
StartPageLogo=pinball
ROMFilter=*.vpt
RomsInFolders=False
RomPath=R:\PinMAME\Tables
SnapPath=
WorkingPath=C:\Emulators\PinMAME
MapKeys=True
WaitBeforeKeys=10000
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=[apppath]\vpauto.exe
Command=..\VPinball-XPFix5.exe -play -"[ROMFILE]"
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
Tom, now that you're back... do you have any idea where I went wrong? Thanks :)
I think you have your paths a bit messed up.
Try these changes:
WorkingPath=R:\PinMAME\Tables
Command=C:\Emulators\PinMAME\VPinball-XPFix5.exe -play -"[ROMFILE]"
Try these changes:
Thanks Tom, that's working much better... just a couple more questions and it should be perfect...
1. When starting it leaves the focus on pinmame, so I have to click on the table to fix it. Any ideas why?
2. When exiting, it's leaving everything open (Exit To Editer, Editer, current Table) and making GameEx it all over top. Do I have to configure something in visual pinball to close it?
Thanks again!
Thanks again!
Have you got this?
MapKeys=False
WaitBeforeKeys=
Have you got this?
MapKeys=False
WaitBeforeKeys=
I tried switching the MapKeys and WaitBeforeKeys to what you said, but the focus on pinmame is still there at start and the exiting doesn't seem to work at all (just stays on the Quit To Editor / Debug / Return box)... so I switched those 2 back to what you had.
This is what I'm at so far...
[Emulator_23]
TITLETEXT=Pinball
ROMFilter=*.vpt
RomsInFolders=False
SnapPath=
MapKeys=True
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
I too was having an issue where I had to click on the table in order to force the game to start. I believe this problem developed when I updated to the newest version of Visual Pinball. With a bit of searching, I found an AutoIt file on the VPForums posted by a guy named eXentric. I just replaced the vpauto.exe that came with GameEX with this one (renamed it to vpauto.exe) and it works fine.
Tom, maybe you want to decompile his script to see what he did different?
Anyway, it's attached here.
vpa1.1.zip
