Has anyone ran into a problem with the Jukebox Next and Previous Song function? You are suposed to use keyboard "a" and "s" (player two button 1 and 2) but the only thing that happens is the playlist jumps to a or s. Has anyone else had this happen to them?
BM
BM
Tom,
Could you help me out with this issue?
BM
Check the settings in the configuration app. I forget where or which one, but I remember that you can turn the controls on and off.
Tom,
BM
I dont really know what it could be off hand. Your deffinitly using the Jukebox and not a playlist?
What sort of controller do you have? Do you have DirectInput enabled?
Ive not heard of or seen this before. Anyone else have this issues.
Found it. Fixed in next release.
