I down loaded and installed all the files on the download page went through the basic setup and gameex fails to load. This is the txt I get.
Win98se SP2(unoffiial), mame061 with a screaming PIII 600EB and 512M ram,NVidia GeForce4 MX 4000.
Thanks in advance
govee :unsure:
10:18:46.2 2/11/07: GameEx: Version 7.58: Starting Log
10:18:46.2 2/11/07: Operating System Platform: Win32Windows
10:18:46.2 2/11/07: Operating System Name: Windows 98
10:18:46.2 2/11/07: Operating System Version: 4.10.67766446
10:18:46.3 2/11/07: Checking for versions of .net Framework installed
10:18:46.3 2/11/07: .net Framework 1.1 Installed
10:18:46.3 2/11/07: .net Framework 2.0 Installed
10:18:46.3 2/11/07: x86 Family 6 Model 8 Stepping 3
10:18:46.4 2/11/07: Running Randomize()
10:18:46.4 2/11/07: Loading PlugIns
10:18:46.5 2/11/07: Checking for applications to Launch On Startup
10:18:46.5 2/11/07: Initialising Video/MNG DLL's
10:18:46.6 2/11/07: Running Misc startup tasks
10:18:46.6 2/11/07: Setting Menu types
10:18:46.6 2/11/07: Opening Configuration File
10:18:46.6 2/11/07: Getting Configuration Values
10:18:46.6 2/11/07: Using Theme: Default - Galaxian
10:18:46.6 2/11/07: Checking for alternate Image Directory for Theme: Default - Galaxian
10:18:46.6 2/11/07: Arcade Mode is on
10:18:46.6 2/11/07: Launching HideOS.exe
10:18:46.6 2/11/07: Hiding Taskbar
10:18:46.7 2/11/07: Is Media Center running?
10:18:46.7 2/11/07: Checking/Creating LCD Registry values
10:18:46.7 2/11/07: Check Media Center Exit/Start Mode
10:18:46.7 2/11/07: Media Center Mode 2
10:18:47.2 2/11/07: Snap Delay set to: 2
10:18:47.2 2/11/07: Get other settings
10:18:47.5 2/11/07: Set: Find emulator artwork on best match basis
10:18:47.8 2/11/07: Start work for Form
10:18:47.8 2/11/07: Getting Original Screen Size
10:18:47.9 2/11/07: Initializing Component
10:18:48.4 2/11/07: Initialising Windows Media Player Component
10:18:48.5 2/11/07: MAME Path is: C:\mame
10:18:48.5 2/11/07: MAME EXE file is: mame.exe
10:18:48.5 2/11/07: ROM Path is: C:\mame\roms
10:18:48.6 2/11/07: Catver.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\catver.ini
10:18:48.6 2/11/07: controls.ini is located at: C:\PROGRAM FILES\GAMEEX\data\controls.ini
10:18:48.6 2/11/07: History.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\history.dat
10:18:48.6 2/11/07: nplayers.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\nplayers.ini
10:18:48.6 2/11/07: MAMEinfo.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\mameinfo.dat
10:18:48.8 2/11/07: Loading Controls.ini map file
10:18:48.8 2/11/07: Snap Path is: C:\mame\roms
10:18:48.8 2/11/07: AVI Snap Path is: C:\mame\snap
10:18:48.8 2/11/07: Flyer Path: Not Found
10:18:48.8 2/11/07: Cabinet Path: Not Found
10:18:48.8 2/11/07: Title Path: Not Found
10:18:48.8 2/11/07: Panel Path: Not Found
10:18:48.8 2/11/07: Manual Path: Not Found
10:18:48.9 2/11/07: Icon Path: Not Found
10:18:48.9 2/11/07: Marquee Path: Not Found
10:18:49.0 2/11/07: Loading Custom Emulators
10:18:49.9 2/11/07: Using 2D Animations
10:18:49.9 2/11/07: Using General Font: HandelGothic BT
10:18:49.9 2/11/07: Using Title Font: HandelGothic BT
10:18:50.0 2/11/07: Initialising DirectDraw
10:18:50.2 2/11/07: Creating DirectDraw Device
10:18:50.2 2/11/07: Using Device: NVIDIA GeForce4 MX 4000
10:18:50.3 2/11/07: Setting Resolution to 640x480 32 bit color
10:18:50.7 2/11/07: Creating DirectDraw Surfaces
10:18:50.7 2/11/07: Creating Primary Surface - Full Screen Mode
10:18:50.7 2/11/07: Creating Back Buffer
10:18:50.8 2/11/07: Loading graphic Surfaces
10:18:51.1 2/11/07: Creating Surfaces Misc and Dialogs
10:18:51.7 2/11/07: Creating Surfaces Volume
10:18:51.8 2/11/07: Creating Surfaces Arrows
10:18:51.8 2/11/07: Creating Surfaces GameEXlogo Text
10:18:51.8 2/11/07: Creating Surfaces Toolbar
10:18:51.9 2/11/07: Creating Surfaces Backgrounds
10:18:52.1 2/11/07: Error: 5 - Value does not fall within the expected range.
10:18:54.0 2/11/07: ERRORS DETECTED: EXITING
