zsnes not playing roms plus other minor problems
I have a registered version of gameex, i have setup most of the emulators i want with it but i am haveing the following problems.
- gameex -
Sometimes when i open Gameex it opens then automaticallly minimizes itself, in fact this happens a lot, is this a common problem or is it my machine that is the problem, idid look in the log file and there is nothing in there to say that something is wrong. i am using the valhalla skin btw
- virtua tennis PC -
this is not really gameex related. i have 4 usb gamepads which i use on my machine which work fine with every other PC game/emulator just fine, but when i try config the buttons it will only work with one of the pads, i.e i configure player 1 just fine but when i try and configure 2-4 the moment i input a command for these it puts the command i used previosly. ex. for the lob button i assign button3 for this action, but when i assign the next button ( shoot ) button3 gets assigned to this even though i pressed a different buttonand this happens on players 2-4.
i also tried to use joy2key but virtua tennis only lets you use 1 player for the keyboard.
- Gens -
I am having trouble getting this to play full screen. i edited the cfg file in gens where it says fullscreen=0 or 1
i changed this to 1 and it does work in gameex but the moment i exit and start again it has totally forgotten the setting. i know i have probably done a noob mistake. but i cannot figure it out
- Zsnes -
i am using the config for this from the configs section, i have changed all of the rom paths/directories. the problem i get is when i try and load a rom from within gameex the screen goes black for a couple of seconds then it goes back to gameex i have tried almost everything and no joy. i have attached the log file from when i try to load zsnes within gameex
- 7zip -
this is more a question than a problem. what does this option mean?
i thought gameex would unzip the 7zip file and show all the roms within gameex rom menu, then allow you to play the roms even if the emulator does not support 7zip. if that is the case then i cannot get this to work but i have only tried this with zsnes wich i already have a problem with.
i have done a search on the whole forum and nothing has helped me with these problems ( accept the chankex wrapper problem i had - headkaze you da man- ).
please help me guys.
thanks
1) GAMEEX:
The minimize problem happens to me if I run something else behind GameEx. When that program comes to the front it minimizes GameEx and I have to maximize it myself before it starts. Most commonly this happens when my Norton kicks in for a scan. Not sure if your problem is similar.
3) GENS:
Go to your gens.cfg file, change that line where it says FULLSCREEN like you did before and save & close it. Then, right click the gens.cfg file, select PROPERTIES and change the check mark to READ ONLY.
4) I don't have ZSNES in front of me, but make sure you open the zsnes.ini file and disable the GUI from there. I'm 99% sure the option is in there. Save it and exit. If this doesn't work, change your GameEx setup for ZSNES to Show Desktop: True and try to launch it again. Post back with your discovery.
5) .7z is geared towards GoodMerge. If you enable GoodMerge support, GameEx will extract the contents of your 7-zip file into a temporary folder and you will be taken to another menu screen that shows the contents of the 7z file. Next time you access a .7z file within the same emulator, GameEx deletes the previously extracted ROMs and unzips the new .7z file.
Hope that helps! :)
thanks for your help Adultery i really appreciate it.
- i think you are right about the minimizing thing. lol
- the gens thing worked fine, thanks man
- the zsnes thing did not work, i disabled the gui in the zsnes.cfg file but gameex would still not work with this, i also set show desktop to yes in the advanced config for zsnes and this still did not work, is there another setting in the zsnes.cfg i should be changin?
- i think i understand the 7zip setting in gameex now but i cannot get this to work. i have a complete set of genisis rom 7zip goodmerge, and i have unzipped a few of the files to test if they do actually work which they do. when i enable the goodmerge option in advance config the roms do actually appear in gameex but when i try to play a game nothing happens, it wont let meselect the game to play within gameex. am i doing somethin wrong?
massop
massop
Does Zsnes work outside GameEx?
yes it does, with all of my ROM's
Turn on show desktop and debug mode. Paste what happens here.
I get the same problem, when i press any key to continue it goes back to game ex,
zsnes DEFINATLEY works outside gameex i have been testing all day.
i cant seem to upload but here is my log.
16:14:08.8 23/01/2007: GameEx: Version 7.09: Starting Log
16:14:08.8 23/01/2007: Operating System Platform: Win32NT
16:14:08.8 23/01/2007: Operating System Name: Windows XP
16:14:08.8 23/01/2007: Operating System Version: 5.1.2600
16:14:08.8 23/01/2007: Checking for versions of .net Framework installed
16:14:08.8 23/01/2007: .net Framework 1.1 Installed
16:14:08.8 23/01/2007: .net Framework 2.0 Installed
16:14:08.8 23/01/2007: Intel® Pentium® M processor 1500MHz
16:14:08.8 23/01/2007: 1.5Ghz
16:14:08.8 23/01/2007: Running Randomize()
16:14:08.8 23/01/2007: Loading PlugIns
16:14:08.8 23/01/2007: Checking for applications to Launch On Startup
16:14:08.8 23/01/2007: Initialising Video/MNG DLL's
16:14:08.8 23/01/2007: Running Misc startup tasks
16:14:08.8 23/01/2007: Setting Menu types
16:14:08.8 23/01/2007: Opening Configuration File
16:14:08.8 23/01/2007: Getting Configuration Values
16:14:08.8 23/01/2007: Using Theme: Default - Valhalla Default 1024x768
16:14:08.8 23/01/2007: Checking for alternate Image Directory for Theme: Default - Valhalla Default 1024x768
16:14:08.8 23/01/2007: Launching HideOS.exe
16:14:08.8 23/01/2007: Hiding Taskbar
16:14:08.8 23/01/2007: Is Media Center running?
16:14:08.8 23/01/2007: Checking/Creating LCD Registry values
16:14:08.8 23/01/2007: Check Media Center Exit/Start Mode
16:14:08.8 23/01/2007: Media Center Mode 2
16:14:08.9 23/01/2007: Text/Language: English
16:14:08.9 23/01/2007: Applying Language/Text
16:14:09.1 23/01/2007: Snap Delay set to: 2
16:14:09.1 23/01/2007: Get other settings
16:14:09.1 23/01/2007: Set: Find emulator artwork on best match basis
16:14:09.1 23/01/2007: Start work for Form
16:14:09.1 23/01/2007: Getting Original Screen Size
16:14:09.1 23/01/2007: Loading ICON
16:14:09.1 23/01/2007: Initializing Component
16:14:09.2 23/01/2007: Initialising Bass Audio Library
16:14:09.3 23/01/2007: Loading default loading screen
16:14:09.3 23/01/2007: Loading Custom Emulators
16:14:09.3 23/01/2007: Loading Emulator 1: Sony Playstation (ePSXe)
16:14:09.3 23/01/2007: Loading Emulator 2: Nintendo SNES
16:14:09.4 23/01/2007: Loading Emulator 4: Jnes
16:14:09.4 23/01/2007: Loading Emulator 5: Nintendo N64
16:14:09.4 23/01/2007: Loading Emulator 9: Sega Genesis Games
16:14:09.5 23/01/2007: Loading Emulator 11: Model2
16:14:09.6 23/01/2007: Using 2D Animations
16:14:09.6 23/01/2007: Using General Font: Trebuchet MS
16:14:09.6 23/01/2007: Using Title Font: Trebuchet MS
16:14:09.6 23/01/2007: Starting GameExtender on: 127.0.0.1:8383
16:14:09.6 23/01/2007: Starting GameExtender Publisher
16:14:09.6 23/01/2007: Initialising DirectDraw
16:14:09.6 23/01/2007: Applying GameEx is Loading Image
16:14:09.7 23/01/2007: Creating DirectDraw Device
16:14:09.7 23/01/2007: Using Device: ATI MOBILITY RADEON 7500
16:14:09.7 23/01/2007: Setting Resolution to 1024x768 32 bit color
16:14:09.7 23/01/2007: Creating DirectDraw Surfaces
16:14:09.7 23/01/2007: Creating Primary Surface - Full Screen Mode
16:14:09.8 23/01/2007: Creating Back Buffer
16:14:09.8 23/01/2007: Version 2 Theme being used. Loading.
16:14:09.8 23/01/2007: Loading Button Data
16:14:09.8 23/01/2007: Loading Font Data
16:14:09.8 23/01/2007: Loading Layout Data
16:14:09.8 23/01/2007: Loading Taskbar Data
16:14:09.8 23/01/2007: Loading graphic surfaces
16:14:09.9 23/01/2007: Creating Surfaces Misc and Dialogs
16:14:09.9 23/01/2007: Creating Surface Volume
16:14:09.9 23/01/2007: Creating Surfaces Arrows
16:14:09.9 23/01/2007: Creating Surfaces GameEXlogo Text
16:14:09.9 23/01/2007: Creating Surfaces Toolbar
16:14:09.9 23/01/2007: Creating Surfaces Backgrounds
16:14:10.0 23/01/2007: Creating Surfaces Toolbar Controls
16:14:10.0 23/01/2007: Creating Surfaces GameEx Logo
16:14:10.0 23/01/2007: Creating Surfaces Home & Exit
16:14:10.0 23/01/2007: Creating Surfaces Snaps
16:14:10.0 23/01/2007: Creating Surfaces Menu and List Bars
16:14:10.1 23/01/2007: Creating Fonts
16:14:10.1 23/01/2007: Creating Menu Font
16:14:10.2 23/01/2007: Creating Game Font
16:14:10.3 23/01/2007: Creating Font Black
16:14:10.5 23/01/2007: Creating Font Black Small
16:14:10.7 23/01/2007: Creating Game Font Faded
16:14:10.7 23/01/2007: Creating Title Font
16:14:10.7 23/01/2007: Restoring Title Font From Cache
16:14:11.6 23/01/2007: Fonts Created Succesfully
16:14:11.6 23/01/2007: Creating Radio Station Genres
16:14:11.6 23/01/2007: Error: Could not create station genres
16:14:11.6 23/01/2007: MAME Path is: C:\Documents and Settings\kasz\Desktop\game box utils\mame32
16:14:11.6 23/01/2007: Cannot Find MAME Path: MAME Disabled
16:14:11.6 23/01/2007: Loading Controls.ini map file
16:14:11.7 23/01/2007: MAME CMD options: -triplebuffer -nowindow -joy
16:14:11.7 23/01/2007: Attempting to load game list
16:14:11.8 23/01/2007: Loading last used Game List
16:14:11.8 23/01/2007: Setting Music Volume
16:14:11.8 23/01/2007: Cannot Load Play List. Check Path and filename
16:14:11.8 23/01/2007: Creating DirectSound Device
16:14:11.8 23/01/2007: Trying: Primary Sound Driver
16:14:11.9 23/01/2007: Loading Sound Files
16:14:11.9 23/01/2007: DirectSound Device Created Successfully
16:14:11.9 23/01/2007: Initialising DirectInput for Gamepad support
16:14:11.9 23/01/2007: Unable to create a joystick device
16:14:11.9 23/01/2007: Playing intro sound file
16:14:11.9 23/01/2007: Initializing MCE Remote
16:14:11.9 23/01/2007: Initialization OK! Starting GameEx!
16:14:12.0 23/01/2007: Testing Main Loop Once: Processing Frame
16:14:12.2 23/01/2007: Testing Main Loop Once: Main Loop ran successfully
16:18:12.7 23/01/2007: Starting Attract Mode
16:22:13.2 23/01/2007: Starting Attract Mode
16:24:09.9 23/01/2007: Validating: Emulator_1: Custom Background:
16:24:09.9 23/01/2007: Validating: Emulator_1: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_1: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_1: Database:
16:24:09.9 23/01/2007: Warning: Emulator_1: Database Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_1: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_1: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_1: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_1: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_1: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_1: Cart Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_2: Custom Background:
16:24:09.9 23/01/2007: Validating: Emulator_2: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_2: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_2: Database: SNES
16:24:09.9 23/01/2007: Validating: Emulator_2: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_2: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_2: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_2: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_2: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_2: Cart Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_4: Custom Background:
16:24:09.9 23/01/2007: Warning: Emulator_4: Custom Background Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_4: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_4: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_4: Database: NES
16:24:09.9 23/01/2007: Validating: Emulator_4: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_4: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_4: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_4: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_4: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_4: Cart Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Custom Background:
16:24:09.9 23/01/2007: Warning: Emulator_5: Custom Background Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_5: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Database:
16:24:09.9 23/01/2007: Warning: Emulator_5: Database Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_5: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_5: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_5: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_5: Cart Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Custom Background:
16:24:09.9 23/01/2007: Warning: Emulator_9: Custom Background Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_9: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Database:
16:24:09.9 23/01/2007: Warning: Emulator_9: Database Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_9: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_9: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_9: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_9: Cart Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Custom Background:
16:24:09.9 23/01/2007: Warning: Emulator_11: Custom Background Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_11: Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Database:
16:24:09.9 23/01/2007: Warning: Emulator_11: Database Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Title Snap Path:
16:24:09.9 23/01/2007: Warning: Emulator_11: Title Snap Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Box Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_11: Box Art Path Does not exist
16:24:09.9 23/01/2007: Validating: Emulator_11: Cart Art Path:
16:24:09.9 23/01/2007: Warning: Emulator_11: Cart Art Path Does not exist
16:24:10.6 23/01/2007: Restoring Emulator Database From Cache
16:24:31.8 23/01/2007: Running: cmd.exe /c E: zsnes.exe "E:\98 drive old\EMULATED\SNES\Chess Master.SMC"
16:24:58.9 23/01/2007: Exiting GameEx!
16:24:58.9 23/01/2007: Saving Settings
16:25:01.0 23/01/2007: Disposing Plugins
16:25:01.0 23/01/2007: Checking for applications to Launch On Exit
O.k after having a very late night trying to get zsnes working, I did it ( yay ) what i did was just delete EVERYTHING and re-download/install zsnes and the roms.
then after that i followed lingpanda's and Adultery's advice and now it is working perfect.
thanks for the help guys ( i am not a noob really :P ).
I am almost there......
