By the way that note in the log, normally means it cant find any gamepads attached to the system. Do they show up in the setup wizard? Do they show up otherwise on the system?
Yes they do. I have two wireless controllers, an old Xbox 360 and a fairly new Xbox Series X controller with up to date firmware. Both are recognized in the setup wizard for settings and can be used in emulators, both standalone and via GameEx. They both seem to work correctly according to joy.cpl.
Some more info: I have an old Win10 setup with GameEx 18.64 (working) and the new one (Win11 Pro with 18.99). I‘ll try to pinpoint things later after work and will report back.
Thanks for looking into this.
I did some installing, please see attachment. It seems to me that it is not related to the Windows version and happened from GameEx 18.84 to 18.85.
18.84 works with Win 11 as well, that‘s not in the attachment
(As for the ini all I can say that it‘s a new configuration from scratch and that there was no text editing or the like).
Thanks for your effort!
You should not need to run it as admin. i wouldnt worry about the os not displaying. it shouldnt affect anything else.
What version of windows 11 is it?
Do you still have the windows 10 rig? Does version 19 work on that? Does an earlier version work on the windows 11 setup?
Like i said, ill find a gamepad and have a look.
Hi Tom, yes the attached dll is working, thank you very much. All problems solved!
btw tried again 19.00 (without the new dll) which is not working. Tried both my Win 10 and Win 11 setups with no difference.
Thank you again for your help!
  • Draco1962 changed the title to [RESOLVED] Gamepad control issues in 18.99
