- upgaded to latest version and pinballX hangs on startup screen.
  in logs, last line is : 21:26:19.79  16/12/2024:  Loading Game Statistics and Scores
- renamed c:\pinballX to c:\pinballX.old and reinstalled fully version 6.32
=> still same issue, pinballX does not start anymore
Update : switched back to 6.11, it works fine
This thread is about exit times, a different issue. Please raise this as a new issue attaching your PinballX.ini and Log.txt files, also state what version of VPX you are running (DX or GL, 10.8 RC?) and if VPX is set to run fullscreen or windowed.
Edited by Draco1962
Split from unrelated topic. Tsk.
@scutters agree this is a bit different, sorry for that and thanks for this new thread !
Attached log.txt + config file
It hangs both with my settings and with default config file from the setup.exe.
When I reinstalled completely from scratch, I started pinballX with database + config from setup and it hangs too
PBX hangs when it is launched, the startup video is not played, just the splash screen is shown, so nothing to do a priori with version of VPX ? Anyway, VPX is 10.8RC4, DX version, exclusive fullscreen
log.txtFetching info... PinballX.iniFetching info...
  • Draco1962 changed the title to [RESOLVED] 6.32 hangs on start
