Hi,
I'm using GameEx 18.84 and CPWizard 2.67, which appear to be the latest version of both. CPWizard works fine from the command line.
When GameEx launches CPWizard prior to a game, the screen focus is not switching to the CPWizard window and the panel is therefore not visible. You can ALT+TAB and see that the CPWizard window was created, just never brought to the front.
If I try to display the controls from GameEx (from the game menu, rather than starting the game), the control panel will eventually be made visible after quite a lot of flickering. Exiting CPWizard will however not return focus to GameEx - you have to ALT+TAB back into GameEx.
I believe I have tried every combination of GameEx and CPWizard display settings, but none of these change the behavior. I'm out of ideas and would appreciate any suggestions.
I've attached the GameEx config and log files.
Thank you!
GameEx.iniFetching info... log.txtFetching info...
Hi Tom - Could you please let me know what version of CPWizard you tested against? After a lot of additional troubleshooting, CPWizard 2.67 (latest version AFAIK) displays the focus issue I am experiencing. I have an old version of CPWizard (2.33) which does not exhibit this behavior; unfortunately it will not properly parse the current MAME XML file format.
I can't seem to find older versions of CPWizard in order to test anything between 2.33 and 2.67.
Just to be clear, without changing any other settings, if I use CPWizard 2.33 within my GameEx config, the panels display properly (just without controls). Changing that to 2.67 (with no other changes to the GameEx config) causes the display focus issue. I have tested literally every display option, combination, etc., in 2.67 and none fix the problem.
Thank you
  On 11/19/2024 at 5:39 AM, Tom Speirs said:
When i tested it, I got it from here:
https://www.baker76.com/cpwizard/
Per the change log, v2.65 is the latest yet the actual version available for download is v2.67:
@Endaar - would you mind attaching (no copy & paste please) a copy of the CPWizard.log file? It may provide a clue as to the error condition you are describing for v2.67.
Just to confirm, I am using 2.67 as downloaded from the earlier link.
I've attached cpwizard.log. There are two attempted uses reflected in the log.
The first was launching a game. When doing so, the screen goes black for a bit (which corresponds to the CPWiz timeout) and then eventually loads into MAME. The panel is never brought to the foreground.
The second attempt was simply viewing the controls from the GameEx menu. The screen will go black, return to GameEx after a few seconds, and then  after returning to GameExdisplay the panel. Once you dismiss the panel, you end up at the Windows desktop with GameEx minimized.
Any help is greatly appreciated. Thanks!
CPWizard.logFetching info...
Thanks so much for addressing this, Tom. Things are now working properly when you play a game, and the CP is displayed as expected.
Unfortunately, "show controls" is still acting up; when you select show controls, I quickly see the desktop, CPWizard displayed for < 1 second, and then end up back in GameEx. I think CPWiz is getting focus very briefly but quickly getting terminated. I've attached another debug file from CPW. The first instance is launching a game, and the second is viewing controls.
Even if you don't/can't fix that, I can't tell you how happy I am to have the play game side of things working. It's greatly appreciated.
Endaar
AltBeast-CPWizard.logFetching info...
Happy to help. i may be able to code a workaround hack and will look into this for you but otherwise CPWizard is a little old now and may have issues itself. i do see source code there though and I know its coded in .net so it should be very easy to edit and compile.
Thanks Tom but no luck. Behavior doesn't change with the new HideOS. Honestly, it's not that big of a deal to me. Is it possible to just turn off "View Controls" entirely while not disabling CPWizard when a game is launched?
Unrelated to this, I am having an intermittent crash to desktop with no errors. The GameEx log doesn't seem to show anything, so I am not sure what info I can provide for you to review.
Thanks again.
Gotcha. I've uploaded the relevant log entries, along with the Windows error reporting data and anything else I could find. Note that the dmp file referenced in the event viewer entry is not present on the file system - no idea why that is. Let me know what else I can do to help. Thank you!
Crash.zipFetching info...
