Hello my friends
I am trying to upgrade Pinballx from 5.1 to 6.1.2 everything seems to install fine until I try it out.
When it launches it is not seeing the real pin3DMD files and will not launch pinballx.
I have reinstalled it thinking I missed a check box but still has the same error.
If I copy the old files back on that drive it launches the old version fine.
Is there a file that can be copied from the old version to the new version to allow the real Pin3dmd to function?
I tried the DMDdevice64.dl and xdmd.dll also xdmdnative.dll with no difference.
Thanks for any help
Thanks for the help
10:33:02.36  10/26/2024:  PinballX Core - Version 6.12 x64
10:33:02.38  10/26/2024:  Microsoft Windows 10 Home 64-bit (8GB)
10:33:02.38  10/26/2024:  Loading Settings
10:33:02.47  10/26/2024:  Launching Startup Program: JoyToKey.exe
10:33:02.47  10/26/2024:  C:\Users\PinBall\Desktop\JoyToKey_en\JoyToKey.exe
10:33:02.49  10/26/2024:  Initialize Component
10:33:02.52  10/26/2024:  Initialize Display
10:33:02.56  10/26/2024:  Testing Flash engine.
10:33:02.63  10/26/2024:  Loading PlugIns
10:33:02.92  10/26/2024:  Loaded Plugin:"Speak Game Names" Version 1 By Tom Speirs
10:33:03.26  10/26/2024:  PlugIn: "Speak Game Names" Initialized OK
10:33:03.26  10/26/2024:  Using Plugin System Version: 1
10:33:03.59  10/26/2024:  Created DirectX BackGlass Window
10:33:03.60  10/26/2024:  Looking for startup images
10:33:03.92  10/26/2024:  Hiding Cursor
10:33:03.94  10/26/2024:  Hiding Taskbar
10:33:03.95  10/26/2024:  Getting GPU and CPU Information
10:33:03.97  10/26/2024:  CPU: AMD Ryzen 5 2400G with Radeon Vega Graphics
10:33:03.97  10/26/2024:  4 cores, 8 threads
10:33:03.97  10/26/2024:  GPU 1: Radeon(TM) RX 580
10:33:03.97  10/26/2024:  Displays: 2
10:33:03.97  10/26/2024:  Loading Font
10:33:04.00  10/26/2024:  Load Game List
10:33:04.05  10/26/2024:  Loading Database: Future Pinball
10:33:04.06  10/26/2024:  Loading Database: Visual Pinball
10:33:04.06  10/26/2024:  Loading Database: VP10
10:33:04.24  10/26/2024:  Loading Database: Physmod
10:33:04.24  10/26/2024:  Loading Custom Database: VP 10.8
10:33:04.25  10/26/2024:  Loading Custom Filter Database: VP10
10:33:04.25  10/26/2024:  Loading Custom Database: Bar Room
10:33:04.27  10/26/2024:  Loading Custom Database: Christmas
10:33:04.29  10/26/2024:  Loading Custom Database: JPSalas
10:33:04.30  10/26/2024:  Loading Custom Database: Kids
10:33:04.34  10/26/2024:  Loading Custom Database: Musical Tables VPX
10:33:04.38  10/26/2024:  Loading Custom Database: New Tables
10:33:04.39  10/26/2024:  Loading Custom Database: Nintendo
10:33:04.40  10/26/2024:  Loading Custom Database: Pauls Favorites
10:33:04.42  10/26/2024:  Loading Custom Database: PuP Packs
10:33:04.45  10/26/2024:  Loading Custom Database: Starlion mods
10:33:04.45  10/26/2024:  Loading Custom Database: The Girls
10:33:04.47  10/26/2024:  Initial load gamelist took: 422ms
10:33:04.51  10/26/2024:  Finding and matching artwork and videos
10:33:06.19  10/26/2024:  Took: 1687ms
10:33:06.19  10/26/2024:  Loading Game Statistics and Scores
Not sure the changes will help but you should upgrade to the latest version 6.16.
Please do so and attach updated copies of your pinballx.ini and log.txt files.
Reinstalled the old version and tested it works fine. really old 3.2
Reinstalled the new version over the old one 6.16 same issue it is not seeing the Pin2DMD on start up.
Here are the log files. I can not find the pinballx.ini where would that be located it is not in the pinballx folder I located a config file is that what you wanted?  and attached that as well.
log 3.28.txtFetching info... log 6.16.txtFetching info... PinballX 6.16.iniFetching info...
I deleted pinballx completely from the pinball machine.
Installed the new 6.16 and it went in without a problem.
Copied all the old folders from the old saved pinballx and everything is good now.
Not sure why the upgrade would not work.
Thanks Tom for your assistance.
  • Draco1962 changed the title to [RESOLVED] Pin3DMD not working after upgrade
