Startup Multiplayer Parameters for Zen Pinball FX
Hi there. As you might know (but most likely not, because it is more than two years ago :) ) I created a prelauncher for number of player selection using the look and feel of the DMD.
Now I finally started using Zens new Pinball FX and are wondering if there are also startup-parameters for the number of players there? On FX3 it worked using "-hotseat_2, hotseat_3, hotseat_4". These don't seem to work on FX.
Most likely there is a list of startup-parameters out there, I just cannot find it.
(I will happily provide a link to my tool again once it is working with FX and M)
Yes I knew that. Nonetheless your link helped reading more detailed. the linked launcher helped because it linked to anothet repo which itself linked to zen ;)
Looks like the hotseat options are still correct. But "classic" has to be removed.
Thx. I think i can work now
