Hi ,
Once in a while I have a text problem that happends on every menu ,main and sub screen .
The only thing that clears it up is a reinstall of GameEx, and has happend about 4 times now and only on this ver of GameEx ?
I am using a arcadeVga card and I think it may be a confict with gameex and that as it dont happen anywere else and every game runs fine ?
I have checked though my log and dont see any thing wrong there either .
Many Thanks .
14:05:59.9 03/01/2007: GameEx: Version 7.09: Starting Log
14:06:00.0 03/01/2007: Operating System Platform: Win32NT
14:06:00.0 03/01/2007: Operating System Name: Windows XP
14:06:00.0 03/01/2007: Operating System Version: 5.1.2600
14:06:00.0 03/01/2007: Checking for versions of .net Framework installed
14:06:00.0 03/01/2007: .net Framework 2.0 Installed
14:06:00.0 03/01/2007: AMD Athlon 64 Processor 4000+
14:06:00.0 03/01/2007: 2.4Ghz
14:06:00.0 03/01/2007: Running Randomize()
14:06:00.0 03/01/2007: Loading PlugIns
14:06:00.1 03/01/2007: Checking for applications to Launch On Startup
14:06:00.1 03/01/2007: Initialising Video/MNG DLL's
14:06:00.4 03/01/2007: Running Misc startup tasks
14:06:00.4 03/01/2007: Setting Menu types
14:06:00.4 03/01/2007: Opening Configuration File
14:06:00.4 03/01/2007: Getting Configuration Values
14:06:00.5 03/01/2007: Using Theme: Default - Soul Calibur
14:06:00.5 03/01/2007: Checking for alternate Image Directory for Theme: Default - Soul Calibur
14:06:00.5 03/01/2007: Arcade Mode is on
14:06:00.5 03/01/2007: Launching HideOS.exe
14:06:00.6 03/01/2007: Hiding Taskbar
14:06:00.6 03/01/2007: Using Cabinet Friendly Control System
14:06:00.6 03/01/2007: Is Media Center running?
14:06:00.6 03/01/2007: Checking/Creating LCD Registry values
14:06:00.6 03/01/2007: Check Media Center Exit/Start Mode
14:06:00.6 03/01/2007: Media Center Mode 2
14:06:00.6 03/01/2007: Text/Language: English
14:06:00.6 03/01/2007: Applying Language/Text
14:06:01.4 03/01/2007: Snap Delay set to: 2
14:06:01.4 03/01/2007: Get other settings
14:06:01.5 03/01/2007: Set: Find emulator artwork on best match basis
14:06:01.5 03/01/2007: Using DirectInput for keyboard input
14:06:01.5 03/01/2007: Start work for Form
14:06:01.5 03/01/2007: Getting Original Screen Size
14:06:01.5 03/01/2007: Loading ICON
14:06:01.5 03/01/2007: Initializing Component
14:06:01.7 03/01/2007: Initialising Bass Audio Library
14:06:03.0 03/01/2007: Loading default loading screen
14:06:03.1 03/01/2007: Loading Custom Emulators
14:06:03.1 03/01/2007: Loading Emulator 1: Nintendo NES
14:06:03.2 03/01/2007: Loading Emulator 2: Super Nintendo
14:06:03.3 03/01/2007: Loading Emulator 3: Nintendo 64
14:06:03.3 03/01/2007: Loading Emulator 4: Nintendo GameBoy
14:06:03.4 03/01/2007: Loading Emulator 5: Nintendo GameBoy Colour
14:06:03.4 03/01/2007: Loading Emulator 6: Nintendo GameBoy Advance
14:06:03.4 03/01/2007: Loading Emulator 7: Colecovision
14:06:03.5 03/01/2007: Loading Emulator 8: Atari 2600
14:06:03.5 03/01/2007: Loading Emulator 9: Atari 5200
14:06:03.6 03/01/2007: Loading Emulator 10: Atari 7800
14:06:03.6 03/01/2007: Loading Emulator 12: Sega Megadrive
14:06:03.8 03/01/2007: Using 3D Alpha Blended Animations. This could be slow
14:06:03.8 03/01/2007: Using General Font: HandelGothic BT
14:06:03.8 03/01/2007: Using Title Font: HandelGothic BT
14:06:03.8 03/01/2007: Starting GameExtender Publisher
14:06:04.0 03/01/2007: Initialising DirectDraw
14:06:04.0 03/01/2007: Applying GameEx is Loading Image
14:06:04.8 03/01/2007: Creating DirectDraw Device
14:06:05.5 03/01/2007: Setting Resolution to 640x480 32 bit color
14:06:05.9 03/01/2007: Creating DirectDraw Surfaces
14:06:05.9 03/01/2007: Creating Primary Surface - Full Screen Mode
14:06:06.0 03/01/2007: Creating Back Buffer
14:06:06.1 03/01/2007: Loading graphic surfaces
14:06:06.2 03/01/2007: Creating Surfaces Misc and Dialogs
14:06:06.6 03/01/2007: Creating Surface Volume
14:06:06.6 03/01/2007: Creating Surfaces Arrows
14:06:06.7 03/01/2007: Creating Surfaces GameEXlogo Text
14:06:06.7 03/01/2007: Creating Surfaces Toolbar
14:06:06.9 03/01/2007: Creating Surfaces Backgrounds
14:06:08.7 03/01/2007: Creating Surfaces Toolbar Controls
14:06:08.8 03/01/2007: Creating Surfaces GameEx Logo
14:06:08.8 03/01/2007: Creating Surfaces Home & Exit
14:06:08.9 03/01/2007: Creating Surfaces Snaps
14:06:08.9 03/01/2007: Creating Surfaces Menu and List Bars
14:06:09.1 03/01/2007: Creating Fonts
14:06:09.1 03/01/2007: Creating Menu Font
14:06:10.1 03/01/2007: Creating Game Font
14:06:10.4 03/01/2007: Creating Font Black
14:06:10.5 03/01/2007: Creating Font Black Small
14:06:10.6 03/01/2007: Creating Game Font Faded
14:06:11.2 03/01/2007: Creating Title Font
14:06:11.2 03/01/2007: Restoring Title Font From Cache
14:06:11.7 03/01/2007: Fonts Created Succesfully
14:06:11.7 03/01/2007: Creating Radio Station Genres
14:06:11.8 03/01/2007: Succesfully created station genres
14:06:11.8 03/01/2007: MAME Path is: C:\Program Files\mame
14:06:11.8 03/01/2007: daphne Path is: C:\Daphne
14:06:11.8 03/01/2007: daphne EXE file is: Daphne.exe
14:06:11.9 03/01/2007: Use daphne on. Daphne.exe will launch games
14:06:11.9 03/01/2007: MAME EXE file is: mame32FXpp.exe
14:06:12.0 03/01/2007: ROM Path is: C:\Program Files\mame2\roms
14:06:12.0 03/01/2007: Catver.ini is located at: C:\Documents and Settings\Player One.ARCADEMACHINE\My Documents\Catver.ini
14:06:12.0 03/01/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
14:06:12.0 03/01/2007: History.dat is located at: C:\Program Files\Mame\history.dat
14:06:12.0 03/01/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
14:06:12.0 03/01/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
14:06:12.0 03/01/2007: Loading Controls.ini map file
14:06:12.0 03/01/2007: Snap Path is: C:\Program Files\Mame\snap
14:06:12.0 03/01/2007: Flyer Path is: C:\Program Files\Mame\flyers
14:06:12.0 03/01/2007: Cabinet Path is: C:\Program Files\Mame\cabinets
14:06:12.0 03/01/2007: Title Path is: C:\Program Files\Mame\titles
14:06:12.1 03/01/2007: Icon Path is: C:\Program Files\Mame\icons
14:06:12.1 03/01/2007: Marquee Path is: C:\Program Files\Mame\marquees
14:06:12.1 03/01/2007: Using Ultimarc AradeVGA
14:06:12.1 03/01/2007: MAME CMD options: -video ddraw -nohwstretch -switchres -nowindow -joy
14:06:12.1 03/01/2007: Attempting to load game list
14:06:12.5 03/01/2007: Loading last used Game List
14:06:12.5 03/01/2007: Loading Start Page
14:06:12.6 03/01/2007: Setting Music Volume
14:06:12.6 03/01/2007: Loading music on thread
14:06:12.6 03/01/2007: Creating DirectSound Device
14:06:12.7 03/01/2007: Trying: Primary Sound Driver
14:06:12.7 03/01/2007: Loading Sound Files
14:06:13.0 03/01/2007: DirectSound Device Created Successfully
14:06:13.0 03/01/2007: Creating ICONS
14:06:13.0 03/01/2007: Restoring Cached ICONS from File
14:06:14.7 03/01/2007: Gamepad/Joystick disabled
14:06:14.7 03/01/2007: Initialising DirectInput for Keyboard support
14:06:14.9 03/01/2007: Initializing MCE Remote
14:06:15.0 03/01/2007: Initialization OK! Starting GameEx!
14:06:15.0 03/01/2007: Testing Main Loop Once: Processing Frame
14:06:15.5 03/01/2007: Testing Main Loop Once: Main Loop ran successfully
14:06:20.5 03/01/2007: Exiting GameEx!
14:06:20.5 03/01/2007: Saving Settings
14:06:22.7 03/01/2007: Disposing Plugins
14:06:22.7 03/01/2007: Checking for applications to Launch On Exit
Im not entirely convinced its related to this version of GameEx. Can you try and give me a much better idea of exactly when this problem kicks in. ie return from certain emulator, background change etc?
Have you changed your avga drivers or made any other system changes? Have you added a new emu that you were not using before?
Sorry bit vage then, every thing is fine one night then from switch on the next day it will start from then , its never happends from a return from a game, the only new emulator is the atari jag which is disabled at the mo.
No new drivers have been installed , apart from .net 2.0 could it be that maybe ??
Thanks .
Thanks .
Do you mean when it does happen, it happens immediatly when GameEx launches? What res are you running gameex at, and what res do you have the desktop at, and how are you launching gameex.
Is the Desktop or GameEx running in 16 bit colour at all or switching to and from, that would deffinitly cause this issue. If you run GameEx in 32 bit colour (without this issue) exit and the only change you make is switth to 16 bit colour, it would do this, im sure. Ill fix the problem, but I think that sums it up :)
Yes it happens from the start of gameex booting, I use the quickres tool to give me a res of 640x480 it should be set at 32 colour but it may be (for some reason ?) set or messed up ,
Ta for your help :)
Hi,
Don't know if it's any help, but I had the blue box thingy problem before as well, but once I reverted back to the default font it cleared up.
Anyways, seeing as Tom is on the case, I'll butt out cos I'm only guessing anyway!
Johnny
Hi,
Johnny
Yeah , that seems to have sovled it , kind of strange that . :)
