Can GameEx be the source of any input lag on MAME?  I wouldn't think so, but I am seeing unbearable lag in games launched from GameEx but not if I run the game directly from the MAME GUI.
Please attach your gameex.ini and log.txt files if you don't mind attaching from after when the lag occurs.
Also, what version of MAME are you using?
I looked at the log and saw that there were some plugins enabled.  I disabled them and the problem went away.  I am not sure which one it is, but will play around with it and see.
Just saw this for the Infoz plugin:
22:50:52.02  4/5/2024:  PlugIn: "Infoz" caused an exception and is being disabled.
22:50:52.02  4/5/2024:  Exception has been thrown by the target of an invocation.
22:50:52.03  4/5/2024:     at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
22:50:52.03  4/5/2024:     at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
22:50:52.03  4/5/2024:     at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
22:50:52.03  4/5/2024:     at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
22:50:52.04  4/5/2024:     at GameEx.PlugIns.InvokeMethod(Object obj, String sProperty, Object oValue)
22:50:52.04  4/5/2024:     at GameEx.PlugIns.InvokeMethod(Object obj, String sProperty, Game_Info140 oValue, Double dPluginVersion)
22:50:52.04  4/5/2024:     at GameEx.PlugIns.InvokeMethod(Object obj, String sProperty, Game_Info oValue, Double dPluginVersion)
22:50:52.04  4/5/2024:     at GameEx.PlugIns.Event_GameExit(Game_Info141 Gi, String GameName, Boolean ForScreenSaver)
The Infoz plugin may only be the one to disable in your testing.
Please upgrade your installation to v.18.64
Even more improvements that may help with the issue you are reporting. Please let us know if resolved or if you need further assistance. Please attach new copies of your gameex.ini and log.txt files if the issue continues.
