[RESOLVED] GameEx 18.59 is not displaying .apng file animations
The Draconus theme on the site does not contain the apng files, however, they are located for download on the GameEx FTP at /-GameEx-/Draco1962_Projects/Tarc-Style_Logos/Spinball within the folders:
Arcade
Console
GameEx_Core
Handheld
Misc
PC
I hope that is helpful.
FYI - I have customized the Draconus theme that I am using to the point that I need to save it and name it something else to avoid future confusion. ðŸ™ƒ
Hi @Tom Speirs - I confirmed that the .apng animations broke with the introduction of 18.57. I was on 18.56 before and just loaded it again and it works.
My current WIP theme Opus Technologia is located in /-GameEx-/Draco1962_Projects/Themes on the FTP or your testing if needed.
Hi @Tom Speirs - 18.60 fixed the issue with the .apng animations. I am using a font with my new theme since I last uploaded it to the FTP called Pirulen Rg. It displays correctly in the menus, but does not render well in the title. Is this something you can address easily with a minor update to the same version? Even something in the Theme.ini that will allow for modifying the font size.
  • Draco1962 changed the title to [RESOLVED] GameEx 18.59 is not displaying .apng file animations
