How to setup and launch GameEx Multiplatform Unity Alpha?
Hi Tom - can you provide some brief instructions on how to configure and launch the GameEx Multiplatform Unity Alpha? Thanks!
I did exactly what I understood you to say and went through the Setup Wizard and do not see anything out of sorts for my setup.
I ran the GameEx Arcade Edition.exe and the following occurred:
Apparently, I am missing something but no clue what if following your instructions to launch one of the three executibles.
GameEx.iniFetching info... log.txtFetching info... Player.logFetching info...
Let me know if it works for you if you don't change anything or much. Otherwise absolutely its not going to work with all modified settings. A lot of stuff is not implemented too yet. For example MAME launches but Emulators don't.
Its an alpha and I'm looking for feedback but not much else at this point. There is a lot of stuff I need to do before I am looking for bug reports.
Thanks for taking a look though buddy. i appreciate it.
Before I tinker again just want to be clear:
- OK to change integrated MAME settings ONLY via Setup Wizard
- Do NOT change anything else (i.e., Themes, add emulators, etc.)
At present and from what I observed in the package, GameEx and AE are sharing the gameex.ini file - is that a correct assumption?
