[RESOLVED] DOF for PinballX points to wrong folder post x64 upgrade
When running PinballX Plugin Manager, then "Configuring' DirectOutput PinballX Plugin... My path shows:
C:\DirectOutput-x64
I need it to point to c:\DirectOutput-x32.
How do I accomplish this?
Is your dof not working ?
I think it is checking if dof can be found and does do a reverse lookup in the registry.
What are your issues with dof?
Correct, my DOF works everywhere except in PBX.  I believe the issue resulted as I accidently registered the the 64bit DOF hence the plugin is looking in the 64bit directory. I'm assuming it needs to point to the 32bit as its a 32bit application. That's the only difference between my 2 setups, 1 I accidently registered the 64bit DOF, no DOF in PBX on that build.
I need to figure out how to change it back in the registry, or how to change the DOF path in the DOF Plugin (possibly the same answer).
I have dof 32 and 64 bit on my cabinet as well, but during circumstances not at home for the coming days, so not able to check for you.
Did you registrated the dof 32 bit ? I think that should do the trick.
Can you post your pinballx log.txt file ? And your pinballx.ini ?
log.txtPinballX.iniNote this is from my test rig which is now on my desk and not hooked up to my vpin. But regardless, you can see that the DOF plugin can't initialize from the log.txt.
My assumption is because its pointed to the x64 DOF folder.
Well yes, that would have been the first thing I tried.
You helped create this plugin correct? Where does the app derive the info for the Direct Output path in the Plugin's Config window? I'm assuming its a registry key. If I know where the app is pulling the info from, then I know what keys to overwrite.
Solved
If you search in registry for the name of your dof64 folder, you will find an entry with the name Code Base. Simply point it to the correct spot and re-register.
Ok. Sorry...
No. All credits goes to swisslizard
 I just did some modifications to mKe it a bit better (functionality)
  On 1/3/2024 at 1:13 AM, MulletLife said:
Solved
Nice. Thing get solved when I sleep.
Good job !
  • Draco1962 changed the title to [RESOLVED] DOF for PinballX points to wrong folder post x64 upgrade
