Did you know that KEGA can use filters like 2xSAI, Bilinear, 2xpm and Super Eagle? I've been using this emulator for a looooong time and I just discovered this recently.
I posted a .zip that contains all the filters you can use. Simply download the .zip and extract the files to KEGA's root directory in a folder called 'plugins'
Then, load KEGA outside of GameEx, select the 'Video' tab and choose your plugin from the 'Render plugins' option.
I don't know how I missed this option for so long!
I hope that's helpful to you fine GameEx users like it was to me. :)
I am pretty sure they are already there in my version...and have been using them for a while.
I don't know where you downloaded your version of KEGA, but they are not included in the default install. I only stumbled across the feature while digging through Steve Snake's forum looking for something else. Then I had to make the files myself - which were more or less the .dll files with a new extension.
I had these too, theres a link for them on the Kega site but its hidden in the old fourm archives from over a year ago, But thanks for posting them here for everyone :D
