Hello all,
I am enclosing 2 logs of gameplay using my legion go. each one I'm playing and switch games a couple of time only for game ex to not launch the game and exit back to game ex. Is there a setting I should have checked for using my legion go? Thanx in advance all.
log2.txtFetching info... log.txtFetching info...
GameEx.iniFetching info...
Edited by DJ Infinity
forgot .ini file
Assuming you are referring to this handheld:
Lenovo Legion Go
Do you know if they are using a full or modified version of Windows 11?
I am concerned that GameEx is not seeing the Windows version.
Also, looks like you are throwing your entire emulator setup at this device. As a sanity check, I suggest starting smaller and getting one or two emulators up and running rather than your entire library.
I think it's a modified Win 11. As always I had the emulators running outside Game Ex before adding them. I think you are right. The modified Win 11 may be the culprit.
I have asked Santa to put this in my stocking:
Asus ROG Ally Extreme
Keep us posted. Maybe Tom will have some ideas as more info is available.
If Santa is good to me I will try GameEx Arcade Edition with minimal bling, starting with Steam integration at first.
I almost bought one of those, I like the size of the legion go's screen. plus micro center here in Indianapolis offered with HDD upgrades. So I got a 2TB upgrade and purchased a 1TB micro SD card.
I will likely upgrade to a larger m.2 drive on it as well. Looking to run some of the emulated handheld games (GB, GBA, Sega GameGear, etc.) as well as some of the more handheld friendly current titles.
Only problem I have on mine is TeknoParrot. And Im guessing its because of the weird win 11 on the device. Everything I've played so far plays well. Even yuzu and rpcs3. Xenia doesnt do bad either if you can find a game it likes.
