  On 10/31/2023 at 11:40 AM, duv67 said:
It works !!
Big thanks.
Afterwards my PC has difficulty keeping up with video playback, especially for puck packs. (Phenom II x6 and gtx 660)
A suggestion to make reading smoother?
In PinballX or in game?
If in PinballX make sure you have the latest LAV codecs installed, and you could try using the YUV420P recording option in PbxRecorder.
For in game issues with pup pack performance you probably need to contact the author via the packs download support thread, or down scale the videos.
In the game, no problem reading.
It's difficult with pinballx!
the latest codecs are installed.
In fact, it is at the recording level that there is a problem!
I played the mp4 on another more powerful PC, it is also choppy during playback
and there is only the beginning of the audio.
I tried with YUV420P, it's the same thing!
If I create the playfield and backglass video separately, the video plays correctly.
On the other hand, I still only have 4 seconds of audio!
The only other thing to try then is to do the recording in two steps. Make sure this box is not ticked in PbxRecorder;
And the try to record just the playfield again. Hope that works, otherwise your hardware might not be up to recording audio and video simultaneously with the current version of PbxRecorder
In fact when I create the video of the playfield separately from the backglass,
in the pbx recorder log it is clearly indicated as created but in the pinballx table folder there is no mp4!
I will have to create the sound file separately or without sound!
Anyhow, thanks for your help.
