Since adding a GRS TS-BSP02 Thunderstick GRS USB Button Hole spinner to my X-Arcade Tankstick, I created a modified version of the table found in the Arcade Controls Wiki to reflect the GRS TS-BSP02 (1024 turn count) and TurboTwist/Spintrak (1200 turn count) spinners to provide the MAME Dial Sensitivity for each game in the list.
Example:
Please be aware that your mileage may vary, but, so far, the settings are close enough and may require some tweaking depending upon other factors, such as custom knob weight, that may require up or down adjustments.
The list was derived from the following sources. It is likely not a complete list of spinners and the counts provided are derived from these lists and not cofirmed by me for validity:
http://forum.arcadecontrols.com/index.php?topic=167242.0
http://wiki.arcadecontrols.com/index.php?title=Spinner_Turn_Count
The calculation used is Counts Per Revolution X 100 / Spinner Turn Count = MAME Dial Sensitivity Setting
Sprinner_Turn_Count_Calc_Table_1040_and_1200.xlsxFetching info...
