ESC into the "Input Assignments ( Player 1 Controls )
Hello Gameex Fans, I have the following problem that I just can't solve 😞 Apparently I'm just too stupid .-). I keep trying to press ESC on a button to get out of a Mame game. I have to do that in "Input Assignments (Player 1 Controls). Whenever I do that and press the ESC key, the Gameex kicks me out of the settings. greetings from Hamburg ( Germany ) Peter.... PLEASE HELP ME .-)
Please attach copies (no copy and paste please) of your gameex.ini and log.txt files for review.
Also, we may need to know more about your setup. Are you using an arcade interface (i.e., Jamma) or just a keyboard and gamepad?
Hello Draco1962,
Thanks for your help. I use joysticks and buttons from "EG Starts Arcade DIY Kit". I'll send the gameex.ini and log.txt soon... thanks and greetings Peter from rainy Hamburg Germany 🙂
Unfortunately, I still haven't figured out how to set the ESC function to a key in order to end the corresponding games and get to the GameEX interface.
By default, ESC exits GameEx. Likely you may need to try to map a separate button for your in-game exit to ALT+F4. I am uncertain if this works for all games.
