GameEx Standard, issue with Daphne icons.
Hello there, I realised that in GameEx is impossible to setup properly the icons folder for Daphne. There is no appropriate option in gameex.ini
if you see in setupwizard probably there is a conflict with the logo option as the "Daphne logo images path" is repeated 2 times and there is no option for icons.
I tried to add manually the line in gameex.ini but no success so far.
I tried with the last version of gameex standard but also tried older versions.
I hope you can do something to fix it.
Thanks in advance
Hi. When requesting assistance with an issue, please attach copies of your gameex.ini and log.txt files (no copy and paste) for review.
Thanks!
Thanks!
Thank you, here you are.
log.txt and GameEx.ini are from an older version I'm using here but I got the same issue with the last GameEx used on a different pc.
thanks again!
log.txt GameEx.ini
@Tom Speirs I confirm the view that was illustrated in the OP for duplicate Daphne Logo paths - is the second one actually for a different type, such as manuals or other images? I am unable to confirm any functional issues as reported as I do not have DAPHNE installed and configured on my gamining rig just yet.
On 9/17/2023 at 11:36 PM, Tom Speirs said:
Hi, sorry for the delay and hoops there, ill look into the duplicate but yes you are correct, icons for Daphne is currently not a feature. Thanks, Tom.
Thank you very much! hope that could be fixed.
best regards
Torkyo
