Hello, in order to mirror Future Pinball's DMD to my real DMD, DMdext must be started first. How do I enter the commands correctly in PinballX to make it work. The command is: start /min "" "dmdext.exe" mirror --source= futurepinball -q --fps 60 -g "[TABLEFILE]" --use-ini="C:\Future Pinball\DmdDevice.ini"
I've already gotten it to work via another frontend.
Remove the 'start /min """dmdext" ' from parameters as you already run dmdext from the exe path (with the line parameter behind it)
@Draco1962can you move this to the general thread ?
  • Draco1962 changed the title to [RESOLVED] Where do I enter the command to start DMdext for Future Pinball?
  On 8/3/2023 at 6:03 PM, JimBeamer said:
Wonderful, finally the right answer after a long search. I made a screenshot of the settings for others. Thanks alot
Well, a long search for you, but a quick response from us with a correct answer 😁
