Hi,
I'm excited about GameEx because it has everything I wanted but I can't seem to run it on my PC ( I want to play around with it on my PC but can't wait to put it in my mame cab)
The log reads:
10:09:06.7 4/06/2005: GameEx: Version 4.05: Starting Log
10:09:06.7 4/06/2005: Operating System Platform: Win32Windows
10:09:06.7 4/06/2005: Operating System Name: Unknown
10:09:06.7 4/06/2005: Operating System Version: 4.10.67766446
10:09:06.7 4/06/2005: Running Randomize()
10:09:06.7 4/06/2005: Running Misc startup tasks
10:09:06.7 4/06/2005: Hiding Cursor
10:09:06.7 4/06/2005: Setting Menu types
10:09:06.7 4/06/2005: Opening Configuration File
10:09:06.7 4/06/2005: Getting Configuration Values
10:09:06.7 4/06/2005: Using Theme: Default - Default
10:09:06.7 4/06/2005: Checking for alternate Image Directory for Theme: Default - Default
10:09:06.7 4/06/2005: Applying Language/Text
10:09:07.0 4/06/2005: Snap Delay set to: 2
10:09:07.0 4/06/2005: Is Media Center running?
10:09:07.0 4/06/2005: Check Media Center Exit/Start Mode
10:09:07.0 4/06/2005: Media Center Mode 2
10:09:07.0 4/06/2005: Get other settings
10:09:07.1 4/06/2005: Launching HideOS.exe
10:09:07.4 4/06/2005: Hiding Taskbar
10:09:07.4 4/06/2005: Start work for Form
10:09:07.4 4/06/2005: Getting Original Screen Size
10:09:07.4 4/06/2005: Loading ICON
10:09:07.6 4/06/2005: Initializing Component
10:09:07.8 4/06/2005: Using General Font: Trebuchet MS
10:09:07.8 4/06/2005: Using Title Font: Trebuchet MS
10:09:07.8 4/06/2005: Initialising DirectDraw
10:09:07.8 4/06/2005: Applying GameEx is Loading Image
10:09:08.0 4/06/2005: Creating DirectDraw Device
10:09:08.0 4/06/2005: Using Device: NVIDIA GeForce4 MX 440
10:09:08.1 4/06/2005: Setting Resolution to 800x600 32 bit color
10:09:08.6 4/06/2005: Creating DirectDraw Surfaces
10:09:08.6 4/06/2005: Creating Primary Surface - Full Screen Mode
10:09:08.6 4/06/2005: Creating Back Buffer
10:09:08.6 4/06/2005: Loading graphic surfaces
10:09:08.9 4/06/2005: ERRORS DETECTED: EXITING
Any suggestions?
Marcb
Don't know if this will help but when I first tried GameEx it ran into a problem trying to load the Daphne emulator which I didn't have installed. Once I disabled it GameEx loaded fine...
Hi,
The log reads:
Any suggestions?
Marcb
First thing, I'd like to know what OS your using as GameEx is detecting it as unknown. It may be a Beta or release candidate?
I think the problem is either down to your OS, or that your video card does not have enough memory. Does it share memory? If so try increasing it.
Let me know.
Thanks.
Tom.
Hi,
Thanks for that, but I do have Daphne and I've set the paths etc....
Let me know.
Thanks.
Tom.
Hi,
I'm running Windows 98se ... come to think of it, it is odd that it's reporting as unknown (?)
The video card isn't sharing memory, it has 128mb on board.
As per usual, I did omit something that may be crucial, on first run, GameEx appeared to be running i.e I saw the 'loading' screen etc.. and then exited without showing the log.
On subsequent runs the loading screen doesn't appear but I can see the window being set up etc.. and then it exits and loads the log..
Got it working!
Tom, you were right, it had to do with the graphics card, I've set a lower resolution and presto, all is working! Thanks and apologies for the hassle...
BTW in case it happens again to someone else:
video card = NVIDIA GeForce4 MX 440 128mb
Resolution failed at : 800 x600
reso working at : 600 x 480
ArcadeVga working fine at 600 x288!
Cheers,
Marcb
Got it working!
Cheers,
Marcb
Hi, I am glad your happy now. I am a little concerned that it wont run at 800X600 on a 128mb card though. I obviously do all my development and testing on win2k and XP, but initially I tried hard to get it working on 98 and 98SE.
I would be really interested to know if you can get it running at 800X600 at 16bit colour and also give 1024 x 768 a try. It think this might be due to an old issue where GameEx would not run at the same resolution that the desktop was running at. Could that be it do you think?
640 X 480 is a little crappy unless your running in ArcadeMode.
Thanks,
Tom.
Hi,
New here.
Tried to install GAmeEX and get error message on start up... 0xc0000135 aplication failed to initialize. Does anyone know what causes this???
Thanks,
BB
Nevermind, .net framework wasn't installed. I thought i installed it a day or two ago but I system restored a day ago also... I must have restored before the .net install...
I hate doing fresh XP installs... so much stuff to get everything working
I think XP is a great product, but I know what you mean.
I would just like one button in XP, that says 'I am not an idiot, change all interface, network, file, and folder options and gui to that affect'. Server 2003 does that by default. :angry:
I need one of those buttons for everything I do...
Finish my work in one day button..
make my boss like me button...
Maybe even one for my forehead :unsure::blink:
Oh, got the software up and running. Works great with mamefx32 / fceu / stella / zsnes.
One question. I can't get the save configuration button to work in the config program i.e. i've been changing all my settings through .ini file. Any clue as to what causes this. I'm not really one to complain about kicking through an ini but I like the gui for the config ^_^
Does the save button do nothing or hang?
If you wait a while, and I mean a while, does it save?
This seems to be a problem a few people are having, it does save but just takes an age.
How much mem do you have?
Thanks.
Thanks.
Yeah, I noticed it saves after hanging for about a minute or so but still hangs. I have athlon xp 2500 with 512 ram. I didn't wait more than a minute though! :lol:
Anywho, I think i have everything setup the way I like it. For now!
BB
BB
Could you test the new version I uploaded last night in the forum please?
