[RESOLVED] GameEx Arcade Edition v.18.51 Menu Controls.
I've installed GameEx Arcade Edition v.18.51 and cannot find any settings for the Menu Controls.  I am looking to change the control key for BACK\EXIT on the menu from default SPACEBAR to a different key.  Thanks.
Hi,
Under Input Settings, there is Keyboard Setting section.
This has BACK as [KeyCode_B]
When running the Application, I press B but it takes me to Games beginning with B
So I've Disabled Letter Select - that makes no difference.  B does not go back on menu - only SPACEBAR
I've swapped BACK and Next Track (so Back is X and Next Track is B - pressing X does not go back on the menu - only SPACEBAR
Any other suggestions ?
Cheers
Looks like SPACEBAR and BACKSPACE are set the same to go back/exit. Not sure what to tell you on this.
Maybe a closer look at your support files might provide a better clue to me or someone else. Can you attach (no copy & paste of contents please) your gameex.ini, log.txt, and custominput.ini files in reply to this message?
Issue resolved. Thank you so much.  Custom keys were set but Enable Custom Keyboard Controls was not ticked\enabled.
Thanks again.
  • Draco1962 changed the title to [RESOLVED] GameEx Arcade Edition v.18.51 Menu Controls.
