Hello.
I am just modding an Arcade1Up Starwars with Gameex Arcade Edition as the front end, and am having it play only a small number of games.
I have started off by only putting StarWars, ESB, and ROTJ roms in the rom folder, but when I do the update list, for some strange reason, its finding those 3 games, but also Splatterhouse !
I have tried it with just one single rom in there, and Update List finds that game plus Splatterhouse. In fact nothing I have tried is stopping it adding Splatterhouse to my games list. I even put "splatter" in the filter in setup, but even that doesn't stop it.
Why is it finding Splatterhouse  (which incidentally doesnt work, so its not finding it elsewhere).
Sorry you are having a problem with your setup. Can you please attach copies of your gameex.ini and log.txt files in reply to this thread for review? Thank you.
Thanks Tom, that did the trick. I don't exactly understand why, as pacman was also in that box, and it wasnt showing pacman in the same way....but not to worry, its looking good now.
Ta.
  • Draco1962 changed the title to [RESOLVED] Splatterhouse wont go ???
