Won't launch cmd for dmdext after upgrade of PinballX
3 dll's to test ... :blink:temperature is getting higher and attic is get hotter...
But as I'm awake early, I will try to test it tomorrow (although I promised scutters to do some other work as well). Choices, Choices, choices....
Think scutters needs to wait :D
Hey Tom
With both versions of XDMD.dll PinballX crashes immediately
Application: PinballX.exe
CoreCLR Version: 6.0.1623.17311
.NET Version: 6.0.16
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException: Could not load file or assembly 'XDMDNative, Version=1.1.8523.3577, Culture=neutral, PublicKeyToken=null'. The located assembly's manifest definition does not match the assembly reference. (0x80131040)
File name: 'XDMDNative, Version=1.1.8523.3577, Culture=neutral, PublicKeyToken=null'
   at PinballX.FrmMain..ctor()
   at PinballX.FrmMain.Main(String[] CmdArgs)
XDMDNative.dll is still in the directory.
Reverting to the XDMD.dll that is shipped with latest version, launched PBX again
Using your (modified?) Pindmd.dll
Pressing launch, shows me 30 seconds of black screen, and DMD is not working during VPX
07:03:40.88  4-5-2023:  Setting default net connection limit to 25
07:03:40.89  4-5-2023:  Started
07:03:41.53  4-5-2023:  Starting Real DMD Thread
07:09:13.42  4-5-2023:  Launch System
07:09:13.42  4-5-2023:  Not Hide Backglass!
07:09:13.42  4-5-2023:  Waiting for threads
07:09:13.47  4-5-2023:  Disposing display
07:09:43.60  4-5-2023:  Shutting down XDMD
07:09:43.87  4-5-2023:  Set Plugin data
07:09:44.23  4-5-2023:  c:\Pinball\Visual pinball\VPinballX.exe -play "c:\Pinball\Visual pinball\Tables\VPX\Cosmic Princess (Stern - 1979).vpx"  -ExtMinimized
07:09:44.28  4-5-2023:  C:\Pinball\PinballX\vpauto.exe
07:09:48.18  4-5-2023:  VPX Full screen exclusive mode detected
07:09:48.18  4-5-2023:  VPX Full screen exclusive focus hack set
07:09:53.34  4-5-2023:  Found PinMAME ROM: princess
07:09:55.30  4-5-2023:  Visual Pinball Player window foreground: 11
pinDMD_log.txtFetching info... XDMDlog.txtFetching info...
Above log files files are at the moment when the VPX is launched
XDMDlog.txtpinDMD_log.txt
Above files are created when returning to PBX again
Complete log file of this test
Downloading the X64 version of pindmd.dll from the website and rename it, results in the same results. When launching directly a game after PBX is launched, takes around 20 seconds, before it actually is starting to launch the table, but the DMD is working
Waiting for screensaver and launch it (actually, screensaver didn't start, but waited a longer period), shows the same behaviour as before. Long wait before XDMD is closing, but stil NO DMD during VPX tablelog.txt
