Won't launch cmd for dmdext after upgrade of PinballX
It really should all be fixed now. Post the log with the latest when you get a chance. Im building it now.
There were definitly some issues so its not you but hopefully all fixed now.
The new version will at least show me if im going crazy! It will report the type of device used.
Aren't we all crazy ???
I will try to get some logs today (but right now, my head feels like it is exploded and didnt drink any booze), maybe others can post logs  as well.
So all is goodi f you don't hear anything.
It must be my Dutch temperament that I moan a lot .... (ask scutters about it 😜)
In the past I tested with Freezys virtual as well and that worked. moved the DMDdevice.ini from virtual to real, gave me hanging pinballX when table was lanched.
I tried 5.94 for me.
PinballX initialized the real DMD correct, and I launched directly a table
Takes again 9 seconds from launch till pinball closes XDMD and starts the emulator command to launch the table
But no DMD within Visual Pinball.
Returning to PBX, give me the DMD video again
Attached are the log files.
When I use Freezy's dmd device64.dll (and remove pindmd.dll from the pinballx directory), the DMD is initialized withing Pinballx and working
13:03:26.70  23-4-2023:  Real DMD Initialized
13:03:26.70  23-4-2023:  Device:DMDDevice.dll
Closing down XDMD is working fast as well, and table works with Vpinmame
but PinballX is not responding
Key's to exit emulator doesn't work.
Alt-tab shows that the backglass video is still their
but at a sudden moment :
Eventlog only shows an app hang event :
Fault bucket 1993404121035946545, type 5
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: PinballX.exe
P2: 1.0.0.0
P3: 641cef7e
P4: 246f
P5: 134217732
P6:
P7:
P8:
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.37396143-1d7d-46f3-b52a-83e0d2938889.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.1d8145a9-12c3-46df-a7cf-9f4ab4f153e0.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.af18e650-bcc2-47df-b6be-ea777094cb3e.tmp.txt
\\?\C:\Users\micha\AppData\Local\Temp\WER.35cbc49d-a72a-43cd-b730-897487c1b852.tmp.appcompat.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.e4d9a539-382d-4286-a45d-5819a8a23b45.tmp.xml
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_PinballX.exe_e3ddf147f596981793f91657772779f23c196d_808ef1e3_0002f110-59ae-4216-a798-a109f18d55fa
Analysis symbol:
Rechecking for solution: 0
Report Id: e843dfc5-b40d-4ef4-b370-d6a8f260e7af
Report Status: 268435456
Hashed bucket: 8f166f380775ca1a0ba9fe7c9025ba31
Cab Guid: 0
Nothing usable/usefull in the WER file as well
log.txtFetching info... XDMDlog.txtFetching info... log_DMDdevice.txtFetching info...
Mike, sorry for the delay.  I did try attract mode and it never came on.  I really never use it, but when I put in a time of 1 or 2 min, it does not start like I would expect.  I also notice the delay to start compared to 5.81.  I really thought it was working in my last post, but I still have issues with VPX tables and the dmd not starting.  When I initially tested, I did not have one failure, but it was only a few tables.  I have not tried the latest version but will load that up here and give it a shot and report back.  The real color dmd sure is cool, but always gives a little more grief.  I just love the look of a real dmd.
  On 4/24/2023 at 2:02 AM, chadman said:
I just opened a closed a bunch of fx3 and vpx tables.  The dmd worked great on all the tables I just tested.  I was using 5.94 for this test.
Nice ! If you launch pinballx, wait for a couple of minutes, and launch a fx3 table. Is that still working as well?
Mike, at least its initializing XMD and PinDMD3 properly for you now. It wasn't doing that the other day.
As far as I can see I fixed everything I could. I have nothing else for now.
Hopefully we will figure it.
You seem to have a huge delay unitializing PimDMD3 or Video playback on DMD. Not sure why.
I'm releasing 5.95 in a minute. It has a 30 second timeout shutting it down rather than 8 seconds.
Just so I can properly identify and highlight the issue for all.
It may well just be you Mike. Don't know yet.
I can see the initialize shutdown also takes about 7.5 seconds for Chadman then later takes around 4 seconds. It is also doing other things here though so could be taking less.
ok. thats not good. So maybe my device is not fine.
On the other side : If I don't use XDMD during PinballX, but initialize FlexDMD via plugin (that also may have a delay during start of Pinballx), when game starts, it just leave FlexDMD open, but stops displaying anaything, so it will not lock the dmd (i asume)
So instead of closing and re-initialize the DMD when game starts/end, it just stop displaying anything on the real DMD when game starts and start displaying when game is stopped. Maybe this is not the propper way and causing memory leaks or high CPU, but never run into a problem of this
Tested 5.96
I have good and bad news :D
But lets wait for that for the screensaver tests
I thought we had some good news as well. but tested more and didn't work quit wel
  1. Launch Table directly after PBX is started
    XDMD is closing fast, but 15 seconds delay after closing down XDMD and set plugin data
    Exiting table shows DMD videos within PBX
  2. Launch same table again after it was closed
    XDMD is closed after 7 seconds when table launch is initiated, After that table is launched quickly
  3. After exiting previous table, wait for screensaver mode and launch Table
    Good news : DMD is showing when table is launched during screensaver mode !
    Bad news : I must have a lot of patience to start a table when I launch it during screensaver mode. As it took nearly 3 1/2 minute before the launch command takes place after the table was launched (and table launch and getting PinballX to background took only 10 seconds)
  4. Exit previous table and wait again for screensaver mode.
    Actually launch of table (executable) now tooks 20 seconds after I pressed the button, but when table was launched, no DMD
    Returning to PinballX results that I don't have DMD videos on the DMD
    I don't see it initialized in the log either
For the test all the plugins where disabled
I really don't have a clue what's going on.
Attached log files, and the XDMDlog.txt
Yeah, its overwrites everytime, and this was when i closed the last table and returned to pinballx. It couldn't initialize the dmd at that moment
My assumption is that xdmd didn't close correctly when table launched and when try to initilize when table closed, it shows this
Mike, I do see the same thing you mentioned.  If I let PinballX sit for 10 min and then start an FX3 table the DMD goes out and never starts again until I relaunch PinballX.
can you post the logs for Tom ?
Also the xdmdlog.txt and pindmd_log.txt
thanks !
Sorry, ive been travelling. Ill take a look. At least we are narrowing it down.
Can you confirm, just leaving it does the same, rather than entering screensaver too?
