Steam games still running in the background after using quit key
Hello,
I use GameEx still long time now mainly for 90's emulated games in 240p on CRT.
With switchres ( tool to change modelines ) I discover I can launch "recent games" in 15 khz on my setup, so i bought some nice "new retro games" on Steam using
some scripting with LauchBefore / LauchAfter.
1/ If the games aren't in C:\ there're not visible in GameEx, any clue ?
2/ The games doesn't close when I push the "quit Button", GameEx get the focus Back and the games still running in the Background.
Don't have any logs/ini to attach at this post  (I'm at work right now).
Have a nice day.
Please attach the files from when the error occurs when you can. Also, you may want to attach any batch files you are using for your launch before/aftter scriptiing if going that route. Thanks.
I have checked logs file Don't see Any warnings/erros about Steam games... I remove LauchBefore / LauchAfter scripts to check if it's the same problems : same problems: Steam Games won't stop.
I find a workaround:I kill the process ( Steam Games ) on LauchAfter and now it's working like other Mame/Emu.
I don't know if we can assumed that this problem is solved, but I can if you want post my 2 .BAT files ( LauchBefore / LauchAfter ) to change and get back screen resolution (low res)  and kill the Process.
