I installed today PBX 5.80 where I can set my settings through GameEx Online.
I notice the following things :
  • When Clicking on Custom mode, the checkboxes are not inline with the next pages.
    For example, If I only select "Menu Applications" and "Auto Exit", "Exit screen" and "Exit Program" and I click "next", it will show "Pinball Arcade", followed by   "Video Recording", "Attract mode" and "Autoexit" After the dialog "Auto Exit", it will show the finished  (Skips "exit screen" and "exit programs"
    (looks like checkbox  checked is showing -2 or something ?)
  • No Joystick settings (even not viewable)?
  • When selecting "Custom" , click on back, select Advanced, will jump to the Custom settings again
    Even saving the configuration, and come back, it doesn't want to get into the advanced screen anymore
  • When browsing a folder, When clicking on the expand button it expands the folder, but focus jumps to top (irritating, If I need to go 7 levels deep on a folder/volume that's on the bottom of the dialog)
  • Browsing Executable, needs to expand the folder to show the files (not clicking on the folder) . Took me 10 minutes to realize it :P (And dialog shows, "Browse Folder", Instead of "Browse executable")
  • Selecting a File, shows the FQDN in the executable path (instead of only the file)
  • Clicking on Finish when all is set, didn't do anything. It just stay in the final screen.
    After I close PBX, I could click the finish Button, but settings file wasn't saved on the system
    My mistake. Finnish should be replaced by a popup "click 'Apply and restart' to make the settings effective"
Hope this is enough for Tom to spend some time on :P
Edited by Mike_da_Spike
Edited fixed issues (or user mistakes :P)
Thanks for the reports. Ive been busy working on it in a live state for several days. Most of it is resolved now but im stil going. There were quite a few issues that I never resolved before.
By the way, you need to click Apply and Reset to save the settings at the top of the page. It should popup once you make a change. It will only apply changes made it doesnt overwrite the whole ini.
1 hour ago, Tom Speirs said:
And thanks again for taking the time to take a look. Not a terrible thing but a little quiet here!
No problem Tom. It's quiet here as well, but dont have much energy to sit behind pc or cab. But I will look this week again and report back
I checked again, and indeed some stuff works better, and I needed to put on my glasses at 5:00 am to see the "Save and restart" option.
Edited the first post. Strike through the issues that are fixed
nice job Tom
