I don't use FP so can't show you mine... but check this post - https://www.vpforums.org/index.php?showtopic=46528
The launch before command you need will depend on the type of DMD you use (virtual or real etc) and also install locations - so if someone does post their settings it may not work on your setup (and we don't know what that is - always attach your log.txt and pinballx.ini files!)
