Hello,
PBX version 5.55 works very well except when loading vpx 10.7 tables!
OK ==> The table loads,
OK ==> The video "laoding" is displayed correctly
NOK! ==> At the end of the video "loading" the images on the DMD.png appear (while the option is disabled in the database pbx),
OK ==> Video "loading" closes
NOK ==> The playfield screen is all black and displays Windows desktop icons
Leave the Table!
OK ==> Back to PBX is ok
Reloading table 1X, 2X, 3X ... Typically, when the tables are reloaded 2 to 3 times, the tables open correctly.
Anyone have the same problem, a solution to help?
Thank you
Bonjour,
PBX version 5.55 marche très bien sauf au chargement des tables vpx 10.7 !
OK ==> La table se charge,
OK ==> La vidéo "laoding" s'affiche correctement
NOK ! ==> A la fin de la vidéo "loading" les images sur la DMD.png s'affiche (alors que l'option est désactivé dans la database pbx),
OK ==> La video "loading" se ferme
NOK ==> L'écran playfield est tous noir et affiche les icones du bureaux Windows
Quit la Table !
OK ==> Retour sur PBX est ok
Rechargement de la table 1X, 2X, 3X ... En générale, au rechargement de la tables 2 à 3 fois, la tables s'ouvre correctement.
Quelqu'un aurait le même soucis, une solution d'aide ?
Merci
I don't have any issues with the latest pbx version with launching vpx 10.7.3vor 10.8 tabbles.
Can you post your log.txt after creating your issues and your pinballx.ini file ?
Thank you
Hi,
Thank you for coming back.
I look to send the pinball X log.txt (I didn't find them this morning before I posted my topic) and the pinball.ini.
Thank you soon
