Does the emulator support command line? Did you attempt to configure it following any of the examples from this thread?
did a forum search for it, So I asked if anyone has it running in their setup. now that I'm sober I'll tinker with it and see if I can get it going thanx.
ok,
make sure you have your games setup in tekno parrot 1st. working path is wherever you have it installed. rompath is the UserProfiles folder.
extension is *.xml
commandline is TeknoParrotUi.exe --profile="[ROMPATH]\[ROMFILE]"
now off to find media etc. I might make a map file for games I have and see if that will work. Also see if I can get marquees added to my marquee sign when launched.
Be sure to add you command line to the thread referenced as it is still sourced by others occasionally. Thanks!
Hint: If you might be able to source media from some of the titles from TaitoType 2, Type X, and Nessica titles.
  On 12/28/2022 at 6:04 PM, DJ Infinity said:
ok,
extension is *.xml
Did someone say "marquee"? You might find this helpful:
  • Draco1962 changed the title to [RESOLVED] Tekno Parrot
