Closing PinballX takes a long time after screen saver mode (pinDMDv3 related?).
Not sure if it is only me, but lately PinballX takes a long time to close.
This happen when screensaver mode (attract mode) is runnign for a while and I want to exit (or shutdown).
My first thought it was coming because I had multiple plugins enabled, but even with all my plugin disabled, I have this issue.
I created a small video and attach the log file from the same time.
it's almost 2 minutes before it closes the back glass video and start with the exit scripts.
When having my plugins (DOF, Statistics, de-randomizer and PinemHi) it can take longer.
Looks like the time to close PBX depends also on the time the screensaver runs.
According to the log the exit is starting at '07:17:08.00  28-11-2022:  Exiting', but the actually exit command was given around 2 minutes earlier
EDIT When I disable my real DMD (pinDMDv3) by changing the pinDMD.ini com port to a non-existing com port. PinballX will close almost immediately when pressing the exit, during a 10 min screensaver mode.
Is this maybe related to the issue that my PinDMD is still active when launching a table after screensaver mode?
The first 55 sec can be skipped.
Edit : Turnign off 'Attract mode ' shows the same behaviour.
When I close PBX, alt-tab to backglass, release alt+tab and hit alt-f4, it closes directly the backglass video and exit PinballX.
log.txtFetching info... PinballX.iniFetching info...
Edited by Mike_da_Spike
Added some comments
